Old 03-11-2017, 10:25 PM
Zman's Avatar
Zman Zman is offline
Default Replacement for AJP clutch master cylinder DOT4
I am looking for a replacement for a DOT 4 AJP clutch master cylinder. I see several people pointing toward the Magura unit but from what I can see they are all mineral oil based. Are people just using DOT 4 in the Magura or are there easy to find o-rings for the slave cylinder to change over to mineral oil?
I saw one person reference a DOT4 KTM Brembo option but I have not been able to find which bike that came from. I found this one that looks good but I am not sure if it has the same output thread.
https://www.amazon.com/KTM-BREMBO-HY...re-bullets-btf
Any help would be appreciated
Old 03-11-2017, 10:58 PM
Zman's Avatar
While searching for the KTM Brembo I found Magura makes a retrofit for DOT 4.
http://www.ktm-parts.com/0020746.html
I am still not sure if this will fit the GG brake line.
Old 03-13-2017, 06:40 AM
Leo's Avatar
Leo Leo is offline
Braktec bought AJP and now make a new version of this master cylinder.
Or you can try http://www.ajpamerica.com/
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 03-13-2017, 07:38 AM
Zman's Avatar
Thank you for the info!
Old 03-14-2017, 11:51 AM
risk74 risk74 is offline
I bought a late model KTM Brembo to fit my 04. I tried unsuccessfully to order a rebuild kit for my AJP, was on back-order for months. The Brembo is great, it moved the engagement point out farther than the AJP, which had to be pulled nearly all the way in to disengage the clutch.
Clutch Master Cylinder DOT 4 Zman "Wanted to Buy" & "Want To Trade" 0 03-11-2017 09:09 PM
Clutch Master Cylinder Cory C Enduro Chassis & Body 2 05-03-2016 03:24 PM
Issue with Clutch Master Cylinder 95jersey Enduro Chassis & Body 10 05-24-2015 12:47 PM
Is it possible to convert clutch slave cylinder to dot4? jan_b Enduro Engine - 2 stroke 7 12-19-2014 12:01 PM
Looking for a clutch master cylinder assembly... SpeedyManiac General Discussions & Announcements 5 05-09-2008 07:06 PM
