Old 10-01-2019, 06:56 AM
eralha eralha is offline
Default EC 300 2018 Starter motor question
Hi,
Is the starter motor on a 2018 300 the same as a KTM 2008-2016?
https://pt.aliexpress.com/item/40000...c008mLz9Z&mp=1
It seems to me.
Old 10-01-2019, 07:01 AM
Nocams Nocams is offline
Yep,350watts for the early ktm, then 2014 they went to the 415w unit.
2011 TXT300R
2018 EC300GP
Old 10-01-2019, 07:33 AM
Do you know witch one does the gasgas have?
Old 10-01-2019, 07:02 PM
415watt mate.
2011 TXT300R
2018 EC300GP
Old 10-01-2019, 11:59 PM
Originally Posted by eralha View Post
Hi,
It seems to me.
It bolts right up but spins in the opposite direction. You will need to take the motor apart and spin the center body 180 degrees.
Old 10-03-2019, 04:45 AM
Thanks for the info!
Old 10-03-2019, 08:16 PM
farmerj's Avatar
farmerj farmerj is offline
But you don't need to pull the end caps off, is that right TGM? Just loosen the bolts a little bit and spin the center body. I took the whole thing apart - pulled the end caps off and the winding out - and then it was very hard to get the brushes back in place.
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 10-03-2019, 11:09 PM
Originally Posted by farmerj View Post
But you don?t need to pull the end caps off, is that right TGM? Just loosen the bolts a little bit and spin the center body. I took the whole thing apart - pulled the end caps off and the winding out - and then it was very hard to get the brushes back in place.
Jeff
I have only done it once but when I did it the back portion was in the center body very tightly, it would not have been possible to spin without taking apart. Yes it was a bit difficult to reassemble but not horrible. Luckily I have long fingers.
Old 10-04-2019, 05:14 AM
Jeff
Thanks for this valuable advice, still waiting on the parts.
Old 10-08-2020, 07:50 AM
Iakovos1 Iakovos1 is offline
Hello TGM can you confirm the direction the GG motor is supposed to turn. My understanding if GG spins CCW and KTM spins CW. is that correct?
Starter (Motor) Question farmerj Enduro Electrical & Wiring 8 10-19-2020 01:25 AM
EC 300 2018 Starter motor eralha Enduro Engine - 2 stroke 6 08-06-2019 05:06 AM
Starter motor mikethebike1127 Enduro Electrical & Wiring 2 12-09-2017 06:48 PM
starter motor pigpen966 Enduro Electrical & Wiring 1 08-30-2016 01:56 PM
04 starter motor pondmore Enduro Engine 4 stroke (including EFI & Exhaust) 2 06-23-2007 04:56 AM
