Old 10-19-2023, 08:53 PM
brider brider is offline
Default '03 EC 300, rear brake weirdness & sanity check
My rear brake has never worked (properly) since I got the bike, no obvious signs of leakage anywhere and the pedal SEEMED like it was firm enough, but there was NO braking action. Swapped in a new MC & reservoir, and verified that the caliper is not frozen and is not leaking, and moves freely on it's sliders. Tons of pad material. Bled the new MC with a vacuum bleeder, and I believe I purged all the air; the pedal feels exactly like it did with the original MC, but there is just NO braking action. Sure, if it's on the crate and I spin the wheel I can lock it with pedal pressure, but riding around the yard I can stomp on it and there's nothing. So:
1. I didn't bleed it properly, and the previous MC & system wasn't bled properly, either (doubt this, doesn't feel like air in the system)
2. The pads themselves are useless blocks and are either contaminated or somehow just not grabbing the disc. Sprayed everything with brake cleaner.
Which is it? Seems obvious, but I should replace the pads so I KNOW their condition, I just have never had a set of pads, front or rear, just NOT work. Do I need to remove the caliper (& wheel) to change the pads?
Opinions?
Old 10-19-2023, 09:34 PM
(F5) (F5) is online now
So I have an 07, but had an 02 but 200. Yes remove wheel I think to get to pads properly. Pads contamination is a thing. Buy something decent.
My 07 300 has 1/2" M/C unlike everything else. I tried CR pattern Cylinder which was rubbish as wrong size.
I got the original resleeved and joy to this day. Check, should be cast into the side with a size.
Old 10-20-2023, 10:54 AM
Thanks, new pads and I'll check the sizing stamps on the MC's. Hadn't thought of that.
Complete Nissin Rear Brake System + Enduro Eng. Brake Disk Guard mcnut Parts 5 01-19-2015 01:13 PM
Sanity check, '06 EC300 rear brake MC rebuild kit? brider Enduro Chassis & Body 2 03-24-2014 08:17 AM
Rear brake pad pin adv rider Enduro Chassis & Body 5 03-28-2013 03:50 PM
float height sanity check krazy Enduro Intake/Carburetion - 2 stroke 7 12-13-2012 01:18 AM
