Old 08-03-2006, 08:46 PM
MattR's Avatar
MattR MattR is offline
Default FAQ Input: Repair gas tank mounting hole at front of frame
Question:
The M6 bolt which secures the gas tank at the front of the frame got stripped out. The frame looks like it has a threaded insert. How do I repair this?
Answer:
The wall thickness of the threaded insert will allow you to retap a slightly larger metric bolt. I used a M7 bolt (which is not very common by the way). I retapped the hole with M7 threads being careful to get the threads cut straight. The new M7 hex bolt uses a 11mm wrench for tightening. However, Allen head bolts are available too.
Add other input if you know how to replace the threaded insert with a new one.
Matt
Current: 2009 Yamaha FZ1
Old 08-17-2006, 05:49 PM
gasgasman's Avatar
I've had good luck with these.
Unlike the Helicoil, they have a shoulder to lock the insert in place.
www.timesert.com
Old 08-18-2006, 10:14 AM
MattR's Avatar
Those look like a nice idea.
Do they come in a M7 thread OD with M6 thread ID? Or is it a M8 thread OD?
Matt
Old 08-18-2006, 06:22 PM
gasgasman's Avatar
The inserts come with their own specific taps.
Here's the engineering specs on the inserts.
http://www.timesert.com/html/engineeringdataM.html
Old 10-17-2006, 08:34 PM
gasgasman's Avatar
MattR.
I got to thinking.
The timesert won't work on the front fuel tank mount, since there's no solid frame to tap into.
There's another fastener called a "blind rivit nut", which Ford uses to mount roof racks on vehicles.
Here's an example.
http://www.gesipausa.com/rivent.htm
I can snag a couple from our body shop if you like.
Old 12-02-2006, 09:36 PM
MattR's Avatar
Thanks for the followup idea. Right now, my M7 thread retap is still holding. If I encounter an issue in the future, I will definitely keep the blind rivet nut in mind. It looks like a good application for it.
Another application this would be good for is to fix my seat bracket. The rivet nut on the rear bracket likes to strip sometimes and I have to crimp/ovalize it a bit for the bolt to stay tight.
Matt
Old 12-03-2006, 05:55 PM
gasgasman's Avatar
.........so I should snag a few from the body shop?
Old 12-03-2006, 06:15 PM
MattR's Avatar
Sure, a couple would be good to have on hand. Thanks!
By the way, can a standard rivet tool/pliers crimp them in place? Not sure on the installation procedure.
Matt
Old 12-07-2006, 06:03 AM
Hawkeye Hawkeye is offline
My bike had the same problem. I used a rivnut from a late model KX subframe available at any Kawasaki dealer. To install, I simply drilled out the frame to make a tight fit to the rivnut, tap it in place and then pull the blind rivet portion tight to the frame by installing a M6 bolt and tightening it until the rivet bottoms out. My fix has lasted 4 seasons, no problems.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 12-07-2006, 07:08 PM
MattR's Avatar
Originally Posted by Hawkeye View Post
...then pull the blind rivet portion tight to the frame by installing a M6 bolt and tightening it until the rivet bottoms out.
Thanks! I thought this method may work but wasn't sure if it would buckle/crush the center portion correctly. Sounds like it worked out fine.
Matt
2002 frame; same as a 2005 frame, or close enough? Trooper Sam Enduro Chassis & Body 0 06-10-2010 09:18 AM
Shroud / tank repair Brian VT Enduro Chassis & Body 1 07-05-2008 02:31 PM
M6 hole under engine? moff747 Enduro Engine - 2 stroke 2 03-19-2008 10:48 PM
FAQ Input : Repairing Tank Inserts for Shrouds. jeffd Enduro Chassis & Body 3 03-03-2008 10:09 AM
Mounting hole locations for Scotts Steering Stabilizer SpeedyManiac General Discussions & Announcements 7 01-23-2007 01:33 PM
