Gas gas ec 300 standard carb settings
Hello i have recently braught a 2002 gas gas ec 300 and in 1st and second gear the powervalve dosent want to kick in unless i let off then go back on the throtle. Its like its too ritch. I have had the carb off ans cleaned it an i want to set the air fuel screw back to factory settings. Its got standard exhaust does any body know how many turns it is or rougly so can get it to run right.
Cheers |
The air screw is set to riding conditions and is adjusted at least once every ride. Well, I know a lot don't do it but you are supposed to for best throttle response. You normally want to be about 1.5 turns out as a general guide.
Does your have a PWK carb? Check to make sure your float isn't adjusted too high, that the jet block gasket isn't leaking, that the jets are clean and genuine OEM brand, and that the hole the needle slides through is perfectly round and not slightly oblong. If it's the original carb it's possible it's just worn out.
How do i check the float is set to correct level?
In the carb section there is a sticky up the top. You have an AS1 carb.
Also do a read through while yer there. Standard needle requires a mod. N1FE or any N1 variant, written on the side?. Get some really sturdy cutters and lop it in two. That is part one of getting the bike running properly. Now you need to buy a new needle and you won't be distracted thinking about trying to make it work with the stock needle. Read threads, buy another needle and enjoy.
Carb settings | kyton | Enduro Intake/Carburetion - 2 stroke | 10 | 09-20-2014 08:31 AM |
Do my carb settings seem right? | candybuddy | Enduro Intake/Carburetion - 2 stroke | 1 | 08-06-2014 04:38 PM |
Apt smart carb settings database, please post your settings | IDAHOSPUD | Enduro Intake/Carburetion - 2 stroke | 8 | 12-13-2013 04:45 AM |
carb settings | chinesegav | United Kingdom | 2 | 01-13-2013 05:44 AM |
EC 300 06 standard carb details | hillbilly | Enduro Intake/Carburetion - 2 stroke | 4 | 06-27-2012 03:22 AM |
