#11
Thanks for the photos but would be handy to know the thickness for a 300.
Will try making my own once I know how wide they are meant to be. Cheers Mark |
#12
If you can draw the profile in a CAD program, anyone with a Waterjet can cut the aluminum easily in your preferred thickness.
Kim
08 TXT 300 06 Gasgas EC200 03 Gasgas EC300 05 Pampera 250 |
#13
Ok, so I take it the thickness is not important then?
How wide can you go before it effects the bike adversly? Cheers Mark |
#14
I will measure my LTR to night and tell you what thickness it is.
2002 Gasgas EC250 (gone not forgotten) 2012 Ktm 300xc 2001 Gasgas EC300 Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!! |
#15
Same thing I was thinking. What effect does the thickness
have on chamber volume and power output? My thought was to make spacers and stack them up with gaskets between them. You could start with maybe 1/4-1/2 inch and see when and where the power or torque changes. Someone, maybe LTR or GG, has already experimented with this and ended up with the thickness they sell as being the optimum. The change may be so slight as not to be even worth the effort. I'll file this away as a future project to get to after all the other foolish projects I have in mind get done. Cheers, Jeff So. Cal. ----------------------------------------------------------- Wence wrote: Ok, so I take it the thickness is not important then? How wide can you go before it effects the bike adversly? Cheers Mark |
#16
Dingo measured his spacer and found it to be 20mm.
Found info on another thread... Cheers Mark |
#17
I have one like yours. It's made by Perfex (it's me!) for $69.95, part number 1198-GE25. It's 3/4" thick, and it makes a very good diference. Much more torque at low RPM. In the very technical trail, you can ride so slow you can feel each explosions in the cylinder. You don't need to change the jetting.
Gas Gas 300 DE 2008 sorry for my english, I'm from Québec! |
EC125 Power Valve and Oil | oldschool07 | Enduro Engine - 2 stroke | 11 | 09-27-2015 02:34 PM |
Power Valve Adjustability | jefgil123 | General Discussions & Announcements | 32 | 01-01-2011 11:12 AM |
Power valve spacer | bitoman | Enduro Engine - 2 stroke | 7 | 06-15-2009 03:47 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
