Shifting Problems
I recently split my cases. Unfortunatly, life impeded the progress resulting in my obvious mistake.
After putting the engine back together, the shifter has to be rotated much further than normal to shift. I was just shifting by hand an rotating the counter sprocket, but it appears that the transmission shifts into neutral, 1st, and 2nd its just the the shifter has to be "thrown" much farther than what it should to shift. I'll be taking the clutch side cover off and splitting the cases, if necessary, again tommorrow to figure out was is wrong. I was hoping maybe someone would have some insight as to what could be causing the problem and what I should be inspecting. Thanks, Josh |
At some point one side of the spring on the shifter shaft that wraps around the pin and the shifter fork popped off the pin. This was causing my problem.
Glad you forund the problem.
2004 GasGas DE250 |
Another 450 with stalling problems | mrsticky | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 06-11-2009 11:37 AM |
07 EC 200 Jetting problems | cooganbr | Enduro Intake/Carburetion - 2 stroke | 4 | 08-15-2008 04:29 PM |
03 300 Problems | Ryan#87 | Enduro Engine - 2 stroke | 3 | 06-15-2008 10:28 AM |
06' ec 200 problems | speed addic | Enduro Engine - 2 stroke | 0 | 02-25-2007 06:44 PM |
Not shifting while under load???? | zero_chances | Enduro Engine - 2 stroke | 4 | 02-16-2007 07:40 AM |
