07 300 clutch noise or groan
Hey Guys,
Just wondering whether it is normal on the 07 300 for there to be a fair bit of clutch noise when clutch lever is out. When clutch is engaged the noise is much quieter. Also is there a quick fix for a kickstarter that won't stay in while riding.(is it the usual spring and ball bearing setup or something different.... I have'nt actually had a good look at it yet. Cheers guys. |
My clutch makes the same noise.
Yes. It's the usual ball bearing/spring in the kick starter. My guess is the ball bearing or spring is missing.
2004 GasGas DE250 |
Thanks Eff, I have very little time to play around with the bike unfortunately as I have two small kids. Any time saved is a help.Do you know why it makes the noise by the way?
Cheers Mark |
Some of the '07 clutch baskets had some mismachined finger fillets that would cause a noise.
I don't have the exact details, maybe Berkyboy can fill us in. |
I'm not sure but I do recall others stating that theirs make some noise. Mine is an '04 however.
2004 GasGas DE250 |
My makes the same noise.
Claude 2019 XC300 2010 Nambotin 300 sold '07 EC300 sold '06 EC300 sold '78 Suzuki RM250C2 '75 Yamaha YZ250B sold |
My 01 clutch is very noisy the 03 not at all
Spend some time on a dry clutch Ducati, the GasGas will seem like the inside of a Mercedes.
Its all normal noise, from tolerances being taken up during the engine power pulses. If you run an alloy skid plate, it will reflect a lot of the engine noise upward to the rider making it sound worse than it is. |
Cheers guys,
I was fairly sure it was nothing to be worried about but thought it's better to be safe than sorry. Mark |
my '07 300 makes that rattle + it also makes a lot of noise when slipping the clutch, but I've decided not to worry about it until it stops.
best fix I found for the kick starter was to replace it w/a Yam 1, about $55. only 1 small kid for me, but he is a busy little dude who doesn't sleep much, so I'm claiming that he counts for 3. |
clacking noise | getndirty | Enduro Engine - 2 stroke | 11 | 09-26-2009 07:54 AM |
Top end noise ? | Link | Enduro Engine - 2 stroke | 7 | 01-17-2008 03:33 PM |
clutch noise? | LAWMAN | Enduro Engine - 2 stroke | 9 | 01-16-2008 08:15 AM |
Bad Noise | roostafish | General Discussions & Announcements | 17 | 01-10-2008 08:30 AM |
Exhaust noise | captainslow | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 12-10-2007 07:26 PM |
