2018 300 chain tension
Manual calls for 30-36 mm between chain and swing arm with the bike on the kickstand. This seems very tight to me. If the rear wheel travels up it is tight as a banjo string. Is this measurement right? Has anyone had problems with this?
Is it supposed to be measured from the chain to the top of the chain guard and not the swingarm? |
50mm is what I?ve set mine at.
2011 TXT300R 2018 EC300GP |
Absolute best way to do it is to get the bike on a stand so the rear wheel is off the ground, drop a linkage bolt out so you can lift the swing arm up freely and get the rear axle, swing arm pivot bolt and front sprocket in line. This is the tightest the chain gets so give yourself a little slack here, say about 5mm. Drop it back down put the linkage bolt back in and measure the slack now with the wheel off the ground. What ever it it is now is the tightest you should ever set it.
Back on a gassy! 2018 EC300! 🤘 Txt 280 07 to make me feel like a gumby again |
You should get three fingers under the chain unless you've hands like Hulk. That's about 53 to 56 millimeters if you prefer to measure it. Measure on different parts of the chain and dont forget that the lower part of the chain must be tight... |
Meh I just stick 3 fingers(between swingarm top & bottom of chain) behind chain slider whilst on a stand.
'18 Gasgas XC250 |
yep,works for measuring whiskey as well.
Is the chain tension on 2018 correct | Larsa | Enduro Chassis & Body | 4 | 08-07-2018 12:46 PM |
Chain tension | CORSA | Enduro Chassis & Body | 7 | 07-24-2017 05:54 AM |
Chain tension | drn51 | Enduro Chassis & Body | 8 | 01-05-2013 12:14 PM |
Chain tension | 300ec | Enduro Chassis & Body | 5 | 10-11-2012 10:41 AM |
Chain tension ? | Link | Enduro Chassis & Body | 4 | 11-25-2007 06:24 AM |
