Old 04-23-2019, 03:13 PM
cladoo's Avatar
cladoo cladoo is offline
Default Fouling plugs
My 2010 300 Nambotin has been fouling plugs quite often for the last couple of years. I thought I had it fixed when I found my crankcase gasket was causing my engine to suck in tranny oil.i fixed that but this week for the first ride of the season it has fouled two plugs already. I've been using the same oil and buy the same gas from the same station. Could I have a bad jug of premix oil? I use Amsoil Saber 80:1 and Shell V Power gas. The bike will run all day with now problems it's just that first start up for the day that it fouls!
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 04-23-2019, 07:30 PM
New plugs gapped correctly? Using a BR8ES/G? I don't rate the irridiums.
Drop the crank case bolt and see if you have excess fuel/oil pooled up in there before the 1st start maybe.
Old 04-24-2019, 01:18 AM
(F5) (F5) is online now
Swap out the coil and cap from another bike for giggles.
Maybe float jet too. What's your mileage like?
Plugs fail due to bad spark or rich mixture. Oil is but a minor inconvenience. We all run 40:1 & cant think last time anyone actually fouled a plug. Usually just get a bit gurgly in top end and you realise that the plug is a year old..
Old 04-24-2019, 08:50 PM
shawbagga's Avatar
Stupid question but you're not leaving it on the choke too long are you? 10 seconds max then just give it revs to warm it up.
'18 Gasgas XC250
Old 04-24-2019, 09:12 PM
cladoo's Avatar
New plug, new cap and high tension lead. New stator as my lighting coil burned out. Not runing rich when it starts. I can ride all day without issues, just on cold start up. Mileage is good. New top end last year and I didn't ride much as we had a OHV fire ban and I hurt myself too! Not leaving the choke on more than 10 secs. There are a few local guys that have had issues with Shell V Power gas doing the same thing on cold starts. So I'm going to try some different gas. If that doesn't work then I will try some other oil.
Claude
2019 XC300
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
Old 04-25-2019, 01:12 AM
What's your needle man? We're all loving the RM250 erm, NEDW I think. Or is it J? Written down somewhere. Well actually about 10foot below where I sit at the breakfast bar. Although it isn't Breakfast. Confusing. . .
On a piece of paper clothespegged to my test power supply. Why didn't I write it in the log book I keep for all my bikes?
It's an Enigma wrapped in a Mystery.
Tied up in a Puzzle.
You know I'm going to try a 170 next weekend. Seem to be needing leaner settings than the others.
Might be the head mods.
So I'm drinking APA. . .
Old 04-25-2019, 07:15 PM
cladoo's Avatar
I've been using a DDK needle for years. I dont see it causing a cold start fouling. My guess is the gas.
Claude
2019 XC300
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
Old 04-26-2019, 01:15 AM
If others have had the same issues on the same fuel, then that's what I'd be looking into.
I know with my car I had some rough idling on cold starts a while back... Only ever first start of the day. I wasn't the only one. Interestingly a few people had the same issues and all found it would resolve by moving from BP Ultimate 98 RON to a 95 RON fuel for a couple tanks. It must have been part of the additive package causing some issues. It was soon after they released their adverts regarding "cleaning the engine" etc... detergents.
Old 04-26-2019, 05:53 AM
That's exactly the combination I used for years in my KTM's- Amsoil 80:1 and shell V-Power and I never had an issue.
Then I bought my first GasGas in 2018 a EC 300GP. And it fouled plugs from day one. Was a a really hard time.
Parts I changed:
Ignition coil, cable and cap (twice once from a GG once from a KTM 300)
ECU
Luckily my mate had bought the same bike and let me use all of his parts. Finally I swapped the carbs but it did not help either. I tried hotter plugs but they fouled too.
I was really gutted and had no clue what to do. 8 rides, 8 plugs. It always fouled the plugs when idling.
Then in my desparation I called James Dean and described him that the problem happens even if I jet the carb extremely lean (for testing) or extremely rich. James asked what oil and fuel are you running and how the bike runs when it is correctly jetted. I told him that the bike really runs almost perfect as I am a jetting nerd. He suggested to empty the tank and carb, fill fresh ethanol free fuel and use a different oil.
So I bought a bottle of Putoline Mx9 oil mixed it 60:1 (only Amsoil I used 80:1) and went for a ride.
All was good. Next ride I used Motul 710 and after that Motul 800 (80:1) and Fuch Silkolene Titanium (80:1,60:1).
The Gasser never ever fouled a single plug!
I contacted Amsoil and had quite a nice conversation with them. The said that they can't stress enough that Amsoil Saber is not to be used in two stroke motorcycles even though it fulfils the required specs and I should stop using it and go for AMsoil Interceptor.
Lesson learned!
I sold the Gasser finally (just to buy a 2019) and the new owner is happy and it never fouled a plug again.
Please try that and let me know what you found.
Cheers Doc
edit: no I did not make the crosscheck. I still do not know was it the Saber oil or the Shell gas or even both. I just use 98 ethanol free fuel of any brand and oil designed specifically for 2 stroke bikes...
Old 04-26-2019, 09:29 AM
cladoo's Avatar
That was my first thought, that the Saber oil was bad. But I've been using it for at over 7 years and only now it's giving me grief?
Claude
2019 XC300
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
Fouling plugs? TavisB Enduro Intake/Carburetion - 2 stroke 9 09-12-2012 09:56 AM
ec300 fouling plugs after jetting ec300 dave Enduro Intake/Carburetion - 2 stroke 14 05-25-2010 07:32 AM
i keep fouling spark plugs??? tom-s Enduro Engine - 2 stroke 7 08-28-2009 01:37 AM
gasser 250 sm spluttering and fouling plugs gasser250sm Enduro Engine - 2 stroke 3 12-06-2008 03:24 PM
Fouling plugs rupecopp Enduro Intake/Carburetion - 2 stroke 3 08-11-2007 03:43 PM
