Old 03-10-2009, 06:02 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Default Oil height
I am changing the oil in my 07 marzocchi forks and am trying to get it clear in my head what does what.
If the standard oil height is 90-100mm and I put in oil up to 120mm (ie less oil), this will give a larger air gap .
By having a larger air gap the suspension will sitting higher or lower in the stroke?
Will sag be effected?
What will characteristics be compared to standard.
Any help will be appreciated.
Cheers guys,
Mark
Old 03-10-2009, 08:30 AM
Eric K Eric K is offline
The oil height has no significant effect on the sag.
The oil height has the biggest effect in the lower portion of the fork travel. As you raise oil height it reduces the space for the trapped air. Reducing the trapped air space increases the effective air pressure at the bottom of stroke. At top of stroke the air pressure is zero if you bleed you forks.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 03-10-2009, 04:26 PM
wence's Avatar
Ok, so increasing air gap will make the forks feel harsher or plusher? When should this happen in terms of progression through the stroke.
Sorry if I am asking the same question in a different way.
I am having trouble with my forks in that they are way to soft and I can't seem to get them right. I am trying to decide whether to icrease air gap to 120 mm as a lot of others have on here or whether to leave it as 90-100mm as standard.
Cheers Mark
Old 03-10-2009, 07:49 PM
DWreck DWreck is offline
If you go from 90-100 up to 120 on your oil level your forks will bottom easier. If you think that they are too soft now I would increase your compression. (adjuster on bottom of fork legs) I believe most consider the stock springs ok for a rider up to 180 pounds. If you are a lot heavier than that springs are probably your problem.
Old 03-11-2009, 01:47 AM
wence's Avatar
If I go from 90mm from top of fork and then change it to120mm from top of the fork I am increasing air gap.
Just making sure we are both on the same page.
This is what you meant...yes?
Cheers Mark
Old 03-11-2009, 06:14 AM
rpduc rpduc is offline
This gets a little confusing because the larger number actually means less oil, more air.
I'm no expert but as Erik already mentioned the effect of the air gap is mostly felt at the bottom of the stroke but more air/less oil (in a general sense) would be "plusher." If you go to 120mm air gap there will be less bottoming resistance, which usually becomes a problem when forks are "too soft."
Maybe describe what you mean by "way too soft."
Have you checked sag? This will help tell you if your springs are the correct rate for your weight. Any good suspension shop (or some of the folks on here) can tell you what springs you need for your weight. No amount of fiddling with oil height, viscosity and clickers can make up for the wrong springs.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 03-11-2009, 06:21 AM
wence's Avatar
Thanks rpduc,
I just wanted someone to say that.
I thought that was the case but was unsure.
When I bought the bike it had a leaky seal and I did the old note trick.
I don't know how long it was leaking for though.
I guess by going to a heavier weight oil I will be adding damping to the fork as thicker oil through athe same size hole therefore one should counteract the other and I should be still slightly more rebound and bottoming resistance than standard even at 120 mm ???
Thanks Mark
Old 03-11-2009, 07:03 AM
Yeah, but the deal is if you have the wrong springs in there no matter how thick or how much oil you have in there the fork will be working in the wrong portion of it's stroke. Think of it like this. The springs hold the bike up and the oil and dampers control the speed of rebound and compression. If the springs are too soft it's like giving up several inches of travel at the get-go.
I had my MC suspension resprung and revalved by Powerband Racing here and it is a COMPLETELY different machine. I'm an old MXer (really old) and hadn't been on a dirt bike for many years. Before I had it redone I thought had completely forgotten how to ride. The thing was impossible to keep on line. Now she's sweet. IMO suspension will always be the FIRST investment I make in a bike.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
My Website
Old 03-11-2009, 07:47 AM
I suggest starting with the simple changes - like the oil level and damping adjustments.
Reducing the air gap (decrease in measured distance to top of oil level) will increase bottoming resistance without making a big difference in the plushness of the initial travel.
Increasing compression damping can help slow down how fast the fork compresses.
If those adjustments are inadequate, then you are looking at spring changes and/or revalving.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 03-11-2009, 01:25 PM
wence's Avatar
Thanks to both of you guys Rpduc and EricK.
I think I will try as Eric said but if no happiness then I will definitely get the suspension done properly by a suspension shop.
I did get my Rmx suspension done by a suspension shop and was very impressed too, it was a completely different bike to ride.
At least now I have it worked out in my head what does what concerning oil, springs and oil height.
Thanks again guys , I'll let you know how it goes after oil change etc.
Cheers Mark
wp 43mm fork oil height stainlesscycle Enduro Suspension 4 07-13-2010 01:13 PM
Fork oil height skid jackson Enduro Suspension 1 08-22-2008 08:24 PM
Fork oil and height JCW Enduro Suspension 5 11-24-2007 10:12 PM
Float height ??? bens25au Enduro Intake/Carburetion - 2 stroke 3 08-01-2007 04:28 AM
Gas Gas Seat Height GregM Enduro Chassis & Body 4 07-20-2006 02:02 PM
