Old 11-08-2006, 08:51 AM
Eric K Eric K is offline
Originally Posted by MattR View Post
Eric,
I assume this measurement was done with the Fastway pegs installed. From your prior post it sounds you are using the Fastways now. If so, then the new shift lever is about 1 inch longer.
FYI...
I have the stock shift lever and Fastway pegs. The distance from back of the shift tip to front of the footpeg = 4 inches.
Matt,
I have the Fastways on my '01 and IMS on my '06 EC.
That measurement was on the '06 EC with the IMS pegs.
With the Fastway pegs on the '06, I estimate that dimension would be about 1/8" shorter since the Fastway pegs are about 1/4" wider overall.
I will measure the distance on my '01 this evening to get a compare.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 11-08-2006, 01:44 PM
iancp5's Avatar
iancp5 iancp5 is offline
I have PivotPegz. You can reverse them which lowers them about a centimetre. And they pivot of course which makes changing gear and braking a lot easier.
Old 11-09-2006, 07:04 AM
The shift lever on the '06 is about 1/2 inch longer than the shift lever on the '01. You will net 1/2 inch more clearance between peg and shifter with the newer shift lever.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 11-11-2006, 07:00 AM
MattR's Avatar
MattR MattR is offline
Eric,
Does the '06 shift lever have a better shifter tip? Mine always gets sloppy and you have to replace it often or rig up a bolt/clamp system.
Matt
Current: 2009 Yamaha FZ1
Old 11-11-2006, 07:54 AM
Treesmacker Treesmacker is offline
After a few e-mails to "Hammerhead Designs" they said they will start
GasGas shifters in 2007. Maybe we should e-mail them a few suggestions?
Old 11-11-2006, 12:14 PM
MattR's Avatar
I emailed them about a year ago and got a similar story. I'm not keeping my fingers crossed on them. I think this would be a great opportunity for someone like LTR, RB-Designs, etc. (with a machine shop) to make up some billet aluminum shifters. I would be the first to buy it if one of our sponsors jumped in and made a few parts. How about a small batch?
Matt
Old 11-12-2006, 07:52 AM
Eric,
Unfortunately, they used the same tip design on the '06.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 11-14-2006, 12:25 AM
motorhead's Avatar
motorhead motorhead is offline
Default hammerhead shifters for gassers
I called them 11-6 to check on progress as I had e-mailed them earlier in the year with a response that they would soon offer one.The guy said the blueprints were drawn but it was on the backburner because of not enough interest,for comparison the new 150 honda mx minibike just came out and they are flooded with request (demand = supply)I told him I would post on gasgasrider and rally the troops to contact the company for a quality alternative.I have no issues with the stock 05' DE 300 shifter (size 11 gaerne),other than I smashed a rock at the last district 17 enduro in indiana and had to lay her down and bounce on the lever to able to shift again.Dont want it to break next time!contact www.shifttip.com remember it never hurts to have a spare shifter in case of.......
seatcover interchange Stoby Enduro Chassis & Body 3 09-04-2010 01:47 PM
parts interchange 125/200 stainlesscycle General Discussions & Announcements 2 12-14-2009 04:59 PM
mc/ec125 rod kit interchange Sierra Gasser Enduro Engine - 2 stroke 1 12-11-2009 07:44 AM
parts interchange mach1m General Discussions & Announcements 1 06-04-2008 11:42 AM
Rod interchange on MC125? mudcovered Enduro Engine - 2 stroke 4 10-18-2007 08:25 PM
