Old 05-10-2008, 11:09 AM
gasIdaho gasIdaho is offline
Default Removing Rear Shock
Getting ready to remove my shock to send to Les. Never done this before. Any tips on what to do (or not to do). I'll probably replace swingarm bearings while I have it torn down.
Thx
05' EC300
Old 05-10-2008, 03:30 PM
PEB PEB is offline
Loosen all the bolts in the linkage, swingarm and shock before taking anything apart. Consider using o-rings, seals or both when putting it back together. While you have it apart replace the chain slider as well.
Paul B
Old 05-10-2008, 03:58 PM
When you say "consider using o-rings, etc" do you mean "replace" the o-rings and seals. Thx for the info!
Old 05-10-2008, 04:27 PM
PEB PEB is offline
Some guys run the seals that came oem. Others replace the seals with O-rings. This last time I had mine apart I replaced the worn bushings and bearings and was able to get a seal and an o-ring on all but a couple of the joints, hopefully creating another layer of protection from muck entering.
Old 06-03-2008, 10:03 AM
JoshP's Avatar
JoshP JoshP is offline
I replaced all mine with Orings and seems to work a lot better than the OEM seals. Also stopped buying bearing from GG since I found a place in Jersey that manufactors them for GG and makes a replace (that GG won't sell) that has a metal track system inside instead of just the pin style. These newer style last about 2 to 3 times in wear since there are extra groves in the design to hold grease (Dare I say that they were like 1/2 the price of the GG's). Although my wear length is probably also due to my habit of cleaning and regrease my bearings every 3 months. I see very little leak through when I do my cleaning sessions. If you are interested in the bearing company I have #'s and Website address some where. Good Luck with it!
Old 07-09-2008, 09:26 AM
AZRickD AZRickD is offline
I'm interested.
I have mine almost apart (trying to get that dang swingarm bolt out).
Old 07-09-2008, 09:58 AM
nhrider's Avatar
nhrider nhrider is offline
Originally Posted by AZRickD View Post
I'm interested.
Did you loosen all the linkage bolts?
2005 YZ 250F
Old 07-09-2008, 07:55 PM
Yeppir. It's just flopping there.
Old 07-12-2008, 06:16 PM
Just got all my suspension components back from the shop. Now, where did I put those dang shims?
Old 02-02-2009, 05:14 PM
AZRick...I'm getting ready to remove my shock but not sure how to go about it. Where did you start as far removing bolts, etc. Does the shock come out the bottom? Not sure I'll be replacing swingarm bearings or not. Just concerned with removing the shock at this point and interested in removing as few a parts as possible. Thx for the input!
ohlins rear shock problem reeve Enduro Suspension 14 06-01-2014 11:03 PM
2010 GG XC 300 Rear Shock Misprint? 2whlrcr Enduro Suspension 3 09-26-2010 11:20 PM
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
Removing shock thelonius General Discussions & Announcements 3 08-30-2007 08:50 PM
