Crank Bearings?
The drive side crank bearing slips on with great ease on my 125. Is this normal? I know of some bigger gasgas motors with the same problem.
Not normal but not uncommon. Happened to our 125XC but on the ignition side. The crank should be split, journal metal sprayed/re-machined, and then rebuilt with a new rod kit. Other than that the GG 125 has been totally bulletproof. Contact Steve @ Motowest.
2001 XC300 Crank shaft bearings | timlh | Enduro Engine - 2 stroke | 0 | 06-23-2010 06:23 PM |
crank bearings | steve | Enduro Engine - 2 stroke | 0 | 02-06-2008 02:51 PM |
2008 Crank Bearings | Skidad | General Discussions & Announcements | 46 | 01-03-2008 09:44 PM |
