Need help identifying some wires (05 EC250)
Tonight I stripped the my bike down a bit. I want to do some cleaning neglected by the previous owner.
I also would like to add back a headlight as well as a tail/brake light. Under the seat I found this wire. Yellow, violet and white. I believe this is for a rear tail/brake light? Then I found these bunched up in front of the gast tank. Two yellow and two violet wires. One pair has "aftermarket connectors" as you can see they're the ones my thumb is holding. I'm guessing possible high beam/low beam or turn signals? If they're turn signals where I my darn headlight wires. Then I found this cluster of wires as well. I know the round black pieces is the coil. But I have no idea what the smaller black square box is. Everything is connected, so I think this part of the wiring is fine.
2005 GasGas EC250 2012 Kawasaki Brute Force 750 w/ EPS Last edited by Koko; 08-23-2012 at 10:52 PM. |
Top one looks like the rear brake light wires. The second looks like the headlight wires. The black box is a rectifier.
2004 GasGas DE250 |
Thank you.
Do you think this switch would work for lights? http://www.rockymountainatvmc.com/p/...Control-Switch I just wish it also had a kill switch to have an all in one control.
2005 GasGas EC250 2012 Kawasaki Brute Force 750 w/ EPS |
Why not just use a simple toggle switch. That is what my bike has. It is mounted behind the number plate and probably costs $2 at radio shack.
2004 GasGas DE250 |
That could work. Partly I was hoping to try and get this road legal. So having the extra functions available on the switch would be good.
I hear yeah! Mass has more rules too.
2004 GasGas DE250 |
I would recommend a "marine grade" 3-way toggle switch. I used them on my off-road only 4x4s for years. Switch in the middle, "off". Switch in down position, "lo-beam". Up position, "HI-beam". Cost: under $20. Just a thought
All healed up, and ready to burn some fat. |
Switch I'm all set on now. I'm confused for the wiring. On my ATV's all I had to do is find a hot wire when the key was on and run a ground.
Now I have 4 wires on my bike. 5 wire connections on the headlight and I have to wire in a toggle switch as well. That's where my confusion comes in. Just a thought...Do two of the wires go to a switch? The other two run to the headlight? Then I just need to run a ground? As for the extra light on the left...the DRL...I could just leave that disconnected. Or feed it power from the main light?
EC-400 FSE - Identifying Fuses | lukemillar | Enduro Electrical & Wiring | 4 | 07-08-2013 03:17 PM |
Too many wires 03 EC125 | fire1998 | Enduro Electrical & Wiring | 3 | 06-10-2012 08:47 PM |
Which wires for horn?? | solstice | Enduro Electrical & Wiring | 0 | 04-09-2012 08:23 AM |
Help with Identifying Particular Skid / Bash Plate | qgstrydom | General Discussions & Announcements | 2 | 07-26-2011 07:14 AM |
2 unplugged wires ec 250 | dareuk | Enduro Electrical & Wiring | 1 | 03-22-2010 03:59 AM |
