#91
23 ounce flywheel weights
Nah I just bought one last week. They sent a new shipment in. Edges are tapered and it has apparently either balancing holes drilled or for getting the weight correct.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
#92
Sent a new one to desertgasser and kept my old one. Must still be rather large ol girl but it's incredible.
#93
I will write something up about it after this weekends race. Sent from my SGH-T999L using Tapatalk |
#94
This is a very interesting thread. I love it.
My 2006 DE300 had the smaller ignition. After I had Ron Black modify my 300's head, tight singletrack rocky off-camber turns instantly became more exciting. Sometimes, my bike's rear end would complete the turn before the front. I then added a 10 oz fww to the flywheel to regain some control. It was a perfect (for me) solution, and worked like a charm. I never experimented with a heavier weight on that bike. (and I still cry about it's theft. ) Looking at the photos posted in this thread, I see that this flywheel weight looks much like the "weight" that came in the original '96-'98 GG 250 counterbalanced engines with the extra lighting windings (Ducatti?) bolted to the inside of the magnesium ignition cover (and that GG later used on the 300cc quad). The "weight" on those ignitions was an "internal rotor" to "excite" the windings. It weighed very close to 23 oz, and had machinings on the underside of the weight to match the protrusions on the outside of the flywheel. When you tightened the separate fw nut, the mating of the machinings to the protrusions locked it in place, instead of only friction doing the job, as is the case with most of the fww that we see on the market. When my son, Josh, first removed this weight from his '97 EC250 flywheel, it had a definite effect on his A-level riding style. In the hare scramble that weekend, he was blowing through turns. In fact, he came into the pits wailing about his brakes, saying that they weren't working. I told him that he was going into the woods with both wheels locked up; and his brakes were working fine. He was simply accelerating faster on the straights than he was used to on that bike (which still had the counterbalancer installed, and so was still running a fairly heavy crankshaft assembly). But, Josh's racing style at the time was very aggressive, and not based on the engine being extremely controllable. I may pull one of these older '97 flywheel weights out of my parts bins, and put it on my secondary bike, a 2004 XC300, just to see what effect it has on it's power delivery. Thank you all again, for analyzing your experiments, and sharing your experiences with the rest of us in such a factual and interesting way. Good Riding! Jim
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#95
23ozFWW
Where are these purchased? Has anyone used PayPal for a payment? Does anyone make a billet stator cover? I mashed my cover good,hit rock which pushed displayed into cover. Which hit hard enough to deform the stator cover.I wouldn't be surprised if the flywheel rubbed the cover.
2012 xc300 - Great bike! sold looking for 18+ |
#96
#97
Wow That's a lot of questions you just shot out. What is the PayPal part? Billet cover has been made. I have one but no longer think they are made. Company was Ransom Machine. https://www.ktm-parts.com/GG-131.html#.U1voKYm9LCQ Sent from my iPhone using Tapatalk
2012 - XC 300 Racing Seattle, WA |
#98
Since adding the shim to my power valve my 300 has been really smooth. The original reason I added the weight was to slow down the hit when the power valve opened. I have been riding my 250 Beta and noticed it would drop into a corner easer than my GasGas. I decided to remove the weight and see how it felt. I could definitely notice a difference. Much easier to initiate the direction change.
#99
Did all gas gas bikes come stock with plastic cover
#100
After a certain year they did. My 97' has a magnesium cover. My 07' and 12' are plastic.
flywheel weights | davedunaway | General Discussions & Announcements | 6 | 01-28-2011 02:52 PM |
flywheel weights kokusan generator | Caravan Monster | All Other Bikes... | 5 | 06-14-2010 11:21 PM |
Flywheel weights | biggstr6 | General Discussions & Announcements | 21 | 03-30-2010 10:54 AM |
Flywheel Weights??? | DAGWOOD1971 | General Discussions & Announcements | 4 | 06-15-2007 11:15 AM |
