Old 02-10-2013, 08:39 PM
erniebearskin erniebearskin is offline
Default E start removal
Ola fellow gassers, how much weight would drop and what is involved in this removal? 2011 EC300.
Bryan
2013 Husaberg TE250 - Current
2011 GasGas EC300 - OLD STEED
2011 Husaberg FE390 - OLD STEED
2010 Yamaha WR250F - OLD STEED
#53B
I dream of a better tomorrow, where Chickens can cross the road, and not be questioned about their intentions.
Old 02-11-2013, 04:04 AM
hawaiidirtrider hawaiidirtrider is offline
I wish I could bolt it up to my 01 300 because I might buy it from you. Why would you take it off? So you save a couple of pounds?.. I don't think it will save as much energy as pushing a button to start.
Old 02-11-2013, 11:34 AM
I have a Rekluse and usually kick my bike over once for the whole day. I thought I read on here it was like 12 lbs weight reduction, thats quit a bit.
Bryan
#53B
Old 02-11-2013, 12:20 PM
I guess that's good if I had or wanted a rekluse but I'm not liking it for a variety of sketchy situations. 12 lbs sounds like a lot.. I guess the battery brings it up but I'd get a lithium light battery to bring that weight down.
Old 02-12-2013, 08:26 AM
As you know it won't bolt up to '01 cases. 12 lb. savings sounds about right, plus the battery portion is up high.
Removing it would rerquire a standard ignition cover and PV cover.
Old 02-14-2013, 08:45 PM
So what would be required with an 01 ? have to change the actual case? or is it a side cover?..or what? The estart kit says something like 99 and up but that doesn't mean more isn't needed like what you've said... Thanks for the info!!!
Ok I just got back from my gasgas dealer today and I see that the case has a flat section by the ignition and my 01 does not. Oh well ... at least I got to see an 11' and 12' gasgas 250 and 300 and a variety of older models here and there. I see a brand new ktm 250 there also.. I've got to say in comparison I think the gasgas is a better bike.. It's not too often that I could see it up close with a brand new gasgas next to a brand new KTM 250/300. . It's not often that there are so many gasgas in one shop ... at least in my experience.. even for a gasgas dealer. usually there's just a couple and not many of the newest. I just showed up at the right day I guess.
Key Removal arminhammer Enduro Electrical & Wiring 11 11-07-2011 07:14 PM
Shock Removal GG27 Enduro Suspension 21 06-17-2010 09:55 AM
Clutch removal help 3hunerd Enduro Engine - 2 stroke 1 05-06-2008 10:32 AM
Dent Removal PEB Enduro Engine - 2 stroke 7 12-27-2007 09:23 PM
