#41
Depends on what you like to ride. If you're riding nothing but smoothy and flowy trail, 6mm. If you plan some log hopping, and possible really rocky terrain, the big 8mm!
WildAzzRacing YouTube channel Trail Riders of Southern AZ club AZ State Parks OHV Ambassador '11 EC250R '98 KDX220 |
#42
Probably the 8mm, I live about 60+miles from the Tennessee Knockout in Sequatchie, tight wooded single track some rocks more or less.
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
#43
AXP Bash Plate No Oil Drain Hole
#44
#45
Yep, I think so too.
#46
Convert to Handlebar Choke
Need a little help, do I disassemble the std choke, then slide the plastic screw and rubber seal around the cable and screw it back into the carb or do I need another plastic part?
#47
why do you want to go that way??? the cable clutch in 99% of GG installations starts playing up and you spend ages trying to work out why your jetting is suddenly off - stick with the plunger choke. (only situation i would go cable is if you do really long sections of WFO riding and want to be able to add a bit more lube to the engine, but you can do that by just holding the kill switch and open the throttle every now and again)
#48
I agree with swazi.
Those cable cause more problems than it's worth. |
#49
Gottcha but.....
I have run this setup on my gasser since 2011, I am comfortable with it.
#50
I can't help with that. Mine came with a Lectron so never dealt with the cable type choke.
POV Graham Jarvis 2022 Romaniacs | Moto7man | Pictures & Videos | 5 | 08-13-2022 12:52 AM |
Final Day Romaniacs 2022 | Moto7man | Pictures & Videos | 4 | 08-07-2022 07:23 AM |
2022 mc350f gap in frame | LANGE135 | Mid-West Forum | 0 | 03-14-2022 10:12 AM |
2022 SWM Model Intro With KYB Suspension | Moto7man | General Discussions & Announcements | 4 | 02-01-2022 10:30 PM |
2022 EX250F FI Issue - on/off throttle transition | NorCalSweet | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 01-26-2022 08:59 AM |
