Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > Pictures & Videos
Old 11-20-2020, 07:58 AM
sn22 sn22 is offline
Looks great, what color is the frame? Nice work!!
Old 04-21-2021, 11:16 PM
Ralley0895 Ralley0895 is offline
Sorry the late late reply. It was tractor supply red powder coat. Unfortunately, they dont sell it anymore... i barely had enough left to get all my parts done.
Old 06-10-2021, 11:51 AM
jerseymike jerseymike is offline
Im new to the forum. Just bought an 03 EC250. Where did you get the new plastics and decals?
Old 06-10-2021, 01:45 PM
Anders Anders is online now
Welcome to the forum! In which part of the world are you located?
Old 06-25-2021, 11:22 AM
Im in eastern/central Ohio. Took the bike out for the 1st time. I havent ridden since 98. My last bike was an 85 CR 500. I know suspension has changed ALOT from that bike. But I have to figure something out on this GasGas because it is no fun! lol. I went for a ride and the front end felt like I was riding on marbles. No i havent done anything with sag or any personal setup yet, but jeeez I almost dont know where to start with the front end.
Old 06-25-2021, 02:41 PM
SS109 SS109 is offline
Start with servicing the suspension and getting proper springs for your weight. Then set your sag. Adjust all clickers to their mid point and locate the forks at the stock height. Then ride it, see how it does, and adjust from there.
Old 06-25-2021, 03:11 PM
I did all that to the suspension today. seemed like front was 26 clicks rebound/comp and rear was 26 rebound, but damn i counted like 70 clicks on the compression. I think the rear has the high/low speed adjustment with the 17mm nut and screw inside of it. I read post here about setup, but front was for Marzochs, I have the Ohlins. But, i found out that one of the bike previous owners has a suspension shop and he races GNCC, so maybe there are heavier springs in there. Waiting on phone call back to see if he remembers the bike. Anyway, also going to get different front tire, Magnum ex on there now, and push forks all way up in trees. Theyre about 12mm up right now.
Old 06-26-2021, 01:15 AM
You don't know how many hours are on the suspension or the spring weight? Without knowing that all other adjustments are pretty much worthless. Everything starts with that. Get it serviced. Suspension should be freshened up (new fluid, possibly seals and bushings) about every 40 hours of ride time or once a year. Also, while having that done have the springs checked to see if they are right for your weight. Any shop worth dealing with can tell you what springs you have in there once they get them apart.
Old 09-10-2021, 09:55 PM
ditezz ditezz is offline
Replace jet block o ring .Always a cause of bad idling and shitty running.No amount o jetting will overcome this You need to do a plug chop to get an accurate plug reading. 40 or 42 pilot .Throw away original needle ,try the Suzuki rm 250 and 180 main AFTER you check /replace O ring .Good luck
Old 11-11-2021, 09:44 PM
Sorry for the late reply.
I bought the plastic off Ebay https://ebay.com/usr/scrubdesignz_europe
Unfortunately finding the headlight is a real pain. I had to search on my laptop and get it shipped to my cousin in Scottland and have her ship it here... cost me too...
Tags
2004, gasgas, rebuild, restoration
84 RM 250 E Ground UP Full Restoration Moto7man All Other Bikes... 212 07-03-2019 09:01 PM
94 CR 250 Ground Up Restoration IMS Wide Ratio Transmission Issue Moto7man All Other Bikes... 146 01-28-2018 05:57 PM
1994 CR 250 Restoration featured on Dirt Bike Magazine Webpage Moto7man Pictures & Videos 8 10-28-2017 09:12 AM
