Old 10-22-2016, 12:48 AM
esskay esskay is offline
Question 2002 EC250 Piston Selection
Hey all, I'm about to do my first top end job on my EC250, and I'm looking towards a Vertex piston unless somebody can recommend a piston that wears better (my bike is getting road registered and will be logging more hours than most so I'm looking for maximum life out of the piston)
My real question:
Is there any way to know if I need an A, B, or C piston without actually ripping the top end off first and measuring?
I'm out in the country and I'll need to order my piston online, and I don't like the idea of the downtime the bike will have with the head off while I'm waiting for a piston to ship, but if standard procedure is to remove everything and measure before I buy then I will do that.
Thanks for the help!
Old 10-22-2016, 01:34 AM
Anders's Avatar
Anders Anders is offline
Usually there is a letter A, B or C stamped into the cylinder. On my 15 200 it is placed close to the base facing rearwards.
Sent fra min E5603 via Tapatalk
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 10-22-2016, 05:14 AM
Cheers man! I'll check that, thanks!
Tags
piston, piston selection, top end
FAQ: Gear ratios and sprocket selection MattR Enduro Chassis & Body 15 03-09-2020 08:00 PM
CR piston on the EC250 mou636 Enduro Engine - 2 stroke 8 02-16-2015 12:44 PM
Piston for a 07 ec250 gasgasandrew Enduro Engine - 2 stroke 0 02-06-2010 02:10 AM
03 EC250 piston kit?? Debi Enduro Engine - 2 stroke 22 01-05-2010 03:11 PM
Springs selection impact on suspension? bergerhag Enduro Suspension 27 06-20-2007 01:58 PM
