Old 02-09-2011, 03:28 PM
RONALD BRUNDIGE's Avatar
RONALD BRUNDIGE RONALD BRUNDIGE is offline
Have you removed the basket and greased or lubed the washer on the back side? I have had plenty of these bikes, never had an issue except in 07 when I was racing mx and forgot to put oil in the bike. oooooppppppppssssss my fault, and I took it apart and pre lubed everything and it was fine after that. Not saying that you have no oil or low on oil but that was the only issue I have ever had with a squeaking clutch on a gasser. Maybe try using green colored springs from the 450? Different oil?, clutch rod?, bleeding fluid or replacing it? or just pound it till something breaks and then you now what it was lol! Good luck on trying to break it cause I have tried and it is tough!!!!!!
DIRT WORLD CYCLES
Old 02-09-2011, 04:55 PM
Clay's Avatar
Clay Clay is offline
Banned
Originally Posted by rgranger View Post
Clay, my dealer is 1,000 miles away. Any chance that you can send me the info? I don't think that there is a GASGAS dealer anywhere near Katy, TX? Also, I forgot to notice it is not just the squawk, but that it didn't turn the bike over.
Thanks !
Rob
Rob,
TJ's in Austin is a GG dealer. 136 miles.
Basically it's an alignment thing. First loosen the starter from the PV cover. If there is a gap, shim it with washers. If it still does it then its an up and down alignment issue. Also, first make sure that the battery is fully charged. That's the biggest problem most times.
Clay
Old 02-10-2011, 12:19 AM
rgranger's Avatar
rgranger rgranger is offline
Ron, just got the bike, haven't done anything yet, first real ride was last sunday.
Clay, thanks I will give that a shot and see what turns out.
Old 02-10-2011, 07:54 PM
Keg Keg is offline
Originally Posted by swazi_matt View Post
my solution to clutch squeal (only under serious abuse!) was to fit a 12 front sprocket. Still top 120+ km/h but bottom is just that little bit easier in the tech stuff.
Now need to sort out the jetting, definitely a little rich
I would run 13/51 before running 12/48. The sprockets and chain will last longer and the effect on the suspension should be better with a larger rear sprocket.
EC300 2019 (11 Gassers owned, many more to go)
Old 02-11-2011, 12:53 AM
swazi_matt swazi_matt is online now
I will prob go that way when i replace the current setup, but for experimenting it is much cheaper to change the front sproket.
I really thought there would be a bigger difference to the top, but I hardly notice it, guess that is the advantage of 6 gears!
2003 txt250 Pro
2013 Ossa 280i
Old 02-12-2011, 11:36 AM
Troy F collins's Avatar
Troy F collins Troy F collins is offline
I agree...Ive done it for years and never noticed any issues..besides its easier and quicker to change back and forth when your out riding
Old 02-13-2011, 12:26 AM
gasgasnz gasgasnz is offline
well had my first ride on my new 300 and my thoughts are yep its squeals too, thinking of adding extra oil and see if that helps? my sidi's catch in the side covers [ fixed with a bit of duct tape], suspensions way too stiff, so much so we revalved the forks in the back of the van at lunch and backed of all sets on the rear and its pretty dam good now, jetting was 180 main 38 pilot and red JD needle and its running very smooth and clean and boy ya got to love that e-start overall yaa hoo
Old 02-13-2011, 08:30 AM
I had read about this earlier. I've racked up 1000+km on my 300 riding in pleanty of slops and ST and have given the clutch a fair working. Yet to hear this sound you all speak of. Strange that some do and some don't.. What temps are people who are experiencing it riding in?? must be some common factor
Tags
2011, clutch, e-starter, ec300, kick starter
cool things found in the woods.. stainlesscycle Ride Reports 28 02-15-2011 11:29 PM
2011 EC300 E-Start dennis brown General Discussions & Announcements 16 12-10-2010 02:16 PM
EC300 SixDays 2011 Elvis74 General Discussions & Announcements 10 09-17-2010 06:05 PM
Some fork oil mods (and other cheap things) AZRickD Enduro Suspension 12 07-21-2008 09:30 AM
