Old 08-21-2019, 10:04 AM
ec300 2013 ec300 2013 is offline
Default Fuel leaks
Hello their,
Mu bike is ec300e 2013 , 2 stroke engine.
My fuel is leaking only when my engine is off.
Its leaking from the excess tube.
If the bike is on so its all good.
Do someone know how can i fix it?
Thanks you verry much
Best regards
Yair
Old 08-21-2019, 01:00 PM
The carb float level needs to be set.
Some good videos can be found on YouTube.
Old 08-22-2019, 05:47 AM
Pygmygod Pygmygod is offline
Yup, check float level in the carb.
I assume only leaking when you put it on the side stand?
Can leak when tilted over too far.
Old 08-23-2019, 03:19 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Remove the carburetor.
Remove the float bowl.
Remove the float and float valve, check and clean. (bit of dirt can stop float valve sealing causing it to overflow).
Replace the float and float valve, check and reset the float height if necessary.
That should fix it.
All the best, Dave.
Old 09-11-2019, 01:54 PM
Hey,
I tried to set the float valve , twice ,
One time i take it down,
And its still leaks,
Next time i curve it up- you can see at the photo.
Connect all and still leaking.....
Old 09-11-2019, 02:35 PM
rodent's Avatar
rodent rodent is online now
Float looks like it's far too far in the hole, straighten the tang out man.
Old 09-11-2019, 03:25 PM
You mean push this metal down?
How much?
Old 09-11-2019, 10:24 PM
At least until the tang is parallel with the float. And do a search to find photos on how to set the float height. You only want the float just resting on the tip to measure it. It should not be compressing the spring.
Old 09-12-2019, 04:33 AM
Maybe my float is damaged?
I dont know... i make it parallel...
Still liking!
Old 09-12-2019, 06:13 AM
There's a measurement to set it, not just bend and away you go.
Read the manual.
Take the little float needle out, the black coating on it may have worn off. Then you'll need to replace it.
Or the seat may have some grit stuck in it preventing the needle from sealing it.
Clean it out with some carb cleaner or at least an earbud rubbed around in the seat hole.
Ohlins Forks 46mm Leaks Leaks and more Leaks Zman Enduro Suspension 8 09-03-2017 07:42 AM
Fuel dye jerry623 General Discussions & Announcements 2 11-24-2014 08:34 PM
no fuel efi stockton Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-08-2014 12:37 AM
fuel & oil knobbyboy Enduro Engine - 2 stroke 4 07-20-2014 05:37 PM
Fuel range and fuel light sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 01-05-2008 02:35 AM
