Old 02-18-2014, 10:50 AM
jt633 jt633 is offline
Default Rear brake pedal crossover?
Does anyone know what rear brake pedal will fit an 04 gasgas for sure? Ive read here kx with mod but doesent specify and ive read kx500 fits just want to be sure will work before i buy my pedal isnt bent at all it just rubs and is very sloppy
2004 ec 300
Old 02-18-2014, 04:49 PM
Fred1956's Avatar
Fred1956 Fred1956 is offline
I haven't personally done it but I believe late model YZ brake pedals work, I don't think anything is a direct crossover though
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 02-18-2014, 11:25 PM
300ECR 300ECR is offline
I had the same problem on my 08 300 so I had I machined out and fitted two needle roller bearings. I fitted it wit a new inner bush and it works better then ever before.
Old 02-19-2014, 05:57 AM
fullthrottle's Avatar
fullthrottle fullthrottle is offline
I fitted a wr450f rear brake pedal, only had to put a few mm spacer between frame and pedal, wind the clevis down to get height and press a spacer in to the frame to suit the wr bolt also streched wr pedal return spring slightly and used that.
End result much better NO slop at all and a pedal that is cheaper to replace stronger and has a better pivot/bearing setup
[/QUOTE]
06 EC250
Old 02-19-2014, 07:36 AM
steliost's Avatar
steliost steliost is offline
try this maybe?
http://www.gasgasrider.org/forum/showthread.php?t=12537
Old 02-19-2014, 06:02 PM
Thanks for the advice guys! What year wr450 did that come from?
2004 ec 300
Old 02-20-2014, 07:07 AM
steliost's Avatar
I believe any year YZ-WR pedal will do. (1998-2008?)
Old 02-20-2014, 04:57 PM
Thanks for the info! Just ordered a nice blue tusk one with a brake snake was gonna get hammerhead one but this one was 20 cheaper
2004 ec 300
Old 03-13-2014, 08:52 PM
Here it is ended up using washers for a spacer ha trouble winding down master clevis
But got it as low as i could
2004 ec 300
Old 03-14-2014, 01:01 PM
Banned
That looks very nice, thanks for posting.
Rear brake pedal wheelie "Wanted to Buy" & "Want To Trade" 1 02-13-2013 01:10 PM
parts crossover - rear brake pedal? stainlesscycle Enduro Chassis & Body 8 06-16-2011 07:05 PM
Brake Pedal 2003 EC 300-KX crossover jb250xcf General Discussions & Announcements 1 03-01-2011 02:36 PM
Rear Brake Pedal Rick Enduro Chassis & Body 4 01-28-2008 01:57 PM
