Old 05-17-2010, 01:30 PM
iancp5's Avatar
iancp5 iancp5 is offline
Default Blue smoke
Hi,
I'm getting blue smoke from my 2006 FSE.
It happens when hot, nothing when cold. If I let it idle for a while and blip the throttle there's a big puff of smoke. If I rev it up and down there's a small amount of smoke both revving up and down. If however I just hold the revs high there's no smoke or at least not enough to see.
Is this piston/rings or valve guides/seals? I'm thinking a new piston and rings?
I should add there is no oil pool sat in the airbox, checked that.
Old 05-18-2010, 08:26 AM
Rick's Avatar
Rick Rick is offline
Maybe try a leak down test??? But blue smoke should point towards rings, valve, guides and or seals......
Good Luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 05-18-2010, 09:16 AM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
Check that you didn't overfill it. At idle the c/case will tend to fill up and may cause some ring blowpast. The 06 sight window is pretty useless as a level as it is full with 1 litre of oil in the engine so it is easy to make a mistake when filling it.
06 Gas Gas FSE 450 USA
07 Gas Gas FSR 450 UK with motard and dirt wheels
Old 05-19-2010, 05:46 AM
iancp5's Avatar
Good point. I'll check.
Old 05-25-2010, 07:55 AM
iancp5's Avatar
Took the oil level right down and still smokes. Have ordered a new piston kit and valve guide seals. Maybe I should get the guides checked too - is there a way I can tell? I only have a simple digital vernier caliper. Have seen people using dial guages but how do you mount one on an aluminium head? Not even sure how much play is alowable. Wondering if I should just take the head to a specialist and have them fit new guides and maybe valves.
Crash "Cage" for 2 smoke pipes rpduc Enduro Chassis & Body 15 01-07-2009 10:13 AM
Red or blue? REVERUP GasGas Member Polls 16 05-10-2008 11:14 PM
White smoke from ignitioncoil =( Anders from Sweden Enduro Electrical & Wiring 5 02-29-2008 04:52 PM
Smoke from Vents PEB Enduro Engine - 2 stroke 3 04-09-2007 07:44 AM
blue and yellow wire dukbil Enduro Engine 4 stroke (including EFI & Exhaust) 1 03-16-2007 09:54 AM
