#11
Ken is def not a hack and very well respected in the north east as well as denny at flotek from va
#12
good to know - you never know on a diy video if it's someone who knows what they're doing, or a hack. i didn't have a chance to look at all his vids to see if his methods are sound, but his transfer port stuff looks good. dremel is the slow and tedious way for sure though.
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
#13
Well, you seal off the cases around the con-rod using duct tape.
You then want to determine what areas of the cylinder and cases you want to grind on. Take a light grease impression from both the surfaces using a spare new gasket placed between the jug and casing. You can repeat this again. If you just remove from one side you may end up with too thin of a mating surface in the end. D'oh! Now grab a Dremel and grind baby grind. Use a metal barrel type bit. Mine had lots of ledge to remove. Lastly, trim the gasket to match as well. |
#14
Thanks lads.
I just cleaned up the dags and gave the exhaust port a polish and matched the edges a bit better on the exh flange this time around. Next time I tear it down I will go into things with more detail. It'll help knowing more about how everything works! |
#15
I'm still betting you'll need a new rear fender on order after the new top end, and S3 head.
Did you buy the GasGas stock piston or did you get a Wossner, ProX, or Wiseco replacement? The only reason I ask is because the piston crown may be shaped differently changing the squish clearance.
'10 EC300 -- very happy |
#16
If you watch his earlier videos he explains he uses a dremel because that's what most people have access to. He also goes on to state for noobs its better as its not gonna take off as much material as a air grinder.
#17
