#31
I was very frustrated when I got my bike and tackled the same issues you're apparently dealing with. It sucks, I'm sorry it's such a hassle on the 18s. You make several won't start statements in the post I quoted. Are some of them won't crank vs won't start? When you mention that it's now harder to start even when kicking it makes me wonder if the temps you were riding in previously have changed and the jetting is close enough to be effected by it. I believe that you are possibly employing far too much faith in the "210cca" and Shoria battery in general. You can help yourself a lot by metering your issues. A couple quick videos show the difference between an advertised 220cca battery that was acting the same as the OEM unit (the oem unit starts a 2017 KTM 300 just dandy with no issues FWIW) You can see that the batteries began with the same charge but did absolutely not act the same once they reached coup d foute and began recovering. Video 2 was same day, same circumstances, cold bike that video 1 was. Drastically different results. 220cca battery https://youtu.be/iuvaMotUd6E the fix https://youtu.be/UltP7VpXFeo |
Swopping 1997 Cylinder head with 2005 head | EC250 | Enduro Engine - 2 stroke | 10 | 12-15-2015 10:13 AM |
200 jug and head | frankinberg | "Wanted to Buy" & "Want To Trade" | 0 | 11-08-2015 05:44 PM |
Coolant leaking through cylinder head socket-head bolts. | GGRider01 | Enduro Engine - 2 stroke | 5 | 10-17-2015 07:38 PM |
How to tell if Head mod has already been done? | 2004ec200 | Enduro Engine - 2 stroke | 4 | 09-08-2014 11:42 PM |
S3 head | bkwdc | Enduro Engine - 2 stroke | 6 | 01-17-2014 01:14 AM |
