Old 12-07-2018, 05:27 PM
yowie05 yowie05 is offline
Default Crank seals
Hi guys does anyone have any specs for the crank seals on an 04 ec300. Bit hard to get gasser parts local(unless someone in Brisbane can tell me where to go) there is a great bearing shop very close and was thinking I?d be able to get them there if I can find specs or even better the numbers off the seal themselves. Also am I able to remove and replace both seal without splitting cases? What tool would I need to remove actual seal, never done seal replacement whilst motor still in bike?
Thx
Old 12-07-2018, 10:19 PM
1 x LHS CRANK SEAL KOK 20x35x6 ? VITON = ktm 47030076100 04-14 105cc 85cc 65cc
1 x RHS CRANK SEAL KOK 38x52x7 - VITON = ktm 0760385273 94-14 250cc & 300cc
Old 12-07-2018, 10:27 PM
Awesome stuff Zman thanks heaps. Any idea on getting these out whilst motor in bike still?
Old 12-07-2018, 11:23 PM
It is tricky but it is possible. I have used a couple fine thread self tapping screws in the side of the seal being very careful not to go too deep or scratch the crank. Then use a slide hammer or some other puller to take it out.
Old 12-08-2018, 12:57 AM
Yer cool was pretty much how I was thinking. Thx
Old 12-08-2018, 08:03 AM
It should not be too bad. It is easier to remove the clutch side seal if you pull the primary gear and the inner sleeve first. It also helps if you warm up the cases with a torch or heat gun. Good luck!
Old 12-08-2018, 04:57 PM
Haha don?t think I?ll use a torch, my luck the oil will catch fire. Might have to see if can borrow a heat gun from someone at work. Either way it a next weekend job. Hopefully the seal are off the shelf item.
Old 12-08-2018, 07:33 PM
I am pretty sure you will fins a seal in those sizes but finding them in Viton may be the challenge. You probably know that Viton is necessary for the fuel compatibility.
Old 12-08-2018, 10:39 PM
Never had a problem finding them in viton. eBay!!
Make sure you assemble the deals with a little 2 stroke or rubber friendly grease on the sealing lips otherwise they won't last long at all!!
2016 RM-Z450
Old 01-27-2019, 06:25 AM
exman exman is offline
Default Crank seals
Are those seals the same for 2012 EC 300? It is not specified in GasGas Parts List.
gasgas 450 ecf 2013 fork seals and dust seals alrighty Enduro Suspension 1 12-21-2016 02:46 PM
Crank seals Toshy Enduro Engine - 2 stroke 5 09-27-2016 01:05 AM
Bad idle after new crank seals adriano.ro Enduro Intake/Carburetion - 2 stroke 3 03-15-2016 11:05 PM
Help please! (Crank seals) spooly Enduro Engine - 2 stroke 13 10-01-2015 07:02 PM
Big End Rebuild - crank seals swazi_matt Enduro Engine - 2 stroke 9 09-18-2015 12:30 AM
