Old 07-10-2013, 10:00 AM
Moto7man Moto7man is online now
Default WTB Rekluse LHRB
Does anyone have one of these for sale. If not, where is the cheapest place to buy one?
―Comedian Lewis Black
-Unknown Sardaukar
Old 07-10-2013, 10:08 AM
pscook's Avatar
pscook pscook is offline
You can build one yourself with a custom length brake hose attached to your clutch master cylinder. If you want to use both the pedal and the hand lever you need to buy an adapter to splice the hand master cylinder into the foot master cylinder. Those aren't cheap, but not too terrible. I'll look for the adapter, I know they are out there. Of course Rekluse sells one, but you are trying to go the other route.
Edit- Here's a link to a junction valve. You would need to contact Geoff directly to see if he makes one for your application. Since you have a 2011, the pictured valve won't work, but there is one available somewhere that will work.
http://www.gptechllc.com/products/gp-tech/thumbrakes
Phil
(New bike pending...)
Old 07-10-2013, 10:42 AM
Darkside Darkside is offline
I have one off my 06. I've had it about a year. I took it off because I plan on selling the bike. It's the rekluse that come with a Magura master and eliminates the foot pedal. Rekluse doesn't make a dual action kit for GG that I know of. PM me if you're interested
2006 GasGas EC300 2011 KTM 300XC
Old 07-10-2013, 11:29 AM
It seems that Rekluse does offer a dual system, see below. Can you send me a photo maybe I can buy the adapter from Rekluse?
-Unknown Sardaukar
Old 07-10-2013, 06:00 PM
Yep. those are the newer bicycle pump kits and have smaller lines and fittings. The older kits are not compatible with the new ones.
Old 07-12-2013, 12:20 PM
firffighter's Avatar
firffighter firffighter is offline
I run a custom LHRB on my KTM. I did a ton of research and found that many prefer the older system that Rekluse sold before they went to this new one. The main complaint with the new system is that you don't get enough power on the LHRB.
I ran a dual set up for awhile and never really used my clutch, so took off my clutch all together and love it.
To make yourself a custom one all you need is a brake line. Speigler can set you up with ease. Simply hook up your brake line from you clutch MC to your rear calliper. Back bleed the fluid and remover your rear brake pedal. Away you go.
It is awesome and the best part of having an auto-clutch. I'll never go back!
Old 09-01-2013, 01:12 PM
IDAHOSPUD IDAHOSPUD is offline
I have the new version, I have to say, I like it better then previous that uses the clutch style control/lever. Much easier to fit both levers on the bars (for me I must keep the clutch lever), and the braking force seems better with the new lever. Clean setup, but spendy.
Old 09-07-2013, 05:42 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Do you think the new Rekluse LH Master Cylinder would be able to supply enough power to run a Brembo dual piston rear brake caliper?
2012 - XC 300 Racing
Seattle, WA
Old 09-08-2013, 08:48 AM
HenrikSchmidt's Avatar
HenrikSchmidt HenrikSchmidt is offline
Exclamation Warning!!
I have to warn you against the new rekluse dual system.
http://rekluse.mybigcommerce.com/yam...model-fitment/
First off all, It's just a overpriced "Hayes" MTB brake master with a Rekluse logo.
Second, is the worst part, the dual action is optained by changing the lid of the original foot operated master to a new Rekluse lid with a thread to fit the brakeline from the LHRB.
That means when you use the LHRB you pressurize the original master from the top, and the brakefluid reservoir is NOT designed to take that kind of pressure!!
My friend fit the system on his GG 300 and it was actually working good, untill he while braking, heard a loud "POP" and the LHRB lost all pressure and his right boot was soked in brakefluid, the level check window in the foot master was gone leaving him with a big hole in his rear master..
Henrik Schmidt
Faster, Faster!!
Until the Thrill of Speed, Overcomes the Fear of Death..
Team YamaGas Racing.
http://bricksite.com/teamyamagasracing
Old 09-08-2013, 11:08 AM
First off all, It's just a overpriced "hope" MTB brake master with a Rekluse logo.
Thats sounds like a big mess. Thanks for the heads up, I think I will pass on the LHRB system for now.
-Unknown Sardaukar
LHRB with standard Clutch lever/cylinder stay_upright Enduro Chassis & Body 5 09-07-2013 05:45 PM
rekluse ??? Moto-x Enduro Engine - 2 stroke 1 03-05-2013 02:54 PM
Rekluse EXP 2.0 for Gas Gas? AZRickD General Discussions & Announcements 13 05-25-2011 06:44 AM
