Old 03-16-2007, 09:23 AM
dukbil dukbil is offline
Default blue and yellow wire
Unplug the blue and yellow wires start fine when cold but when warm sometimes hard to start,seen to rich have to give it throttle to start blows black smoke.Can I mount a toggle switch in line on blue and yellow wire start on lean setting then switch to race map? Thanks,Bill
Old 03-16-2007, 09:54 AM
jeffd jeffd is offline
This might work - it depends on whether the firmware checks the setting value on "power up reset" or whether it is "polled" while the bike is running.
If it were me - I would try to fix the root cause first. Simple stuff first - like cleaning the air filter and making sure it isn't over-oiled. The fuel mixture can be trimmed to some degree with laptop software - I think your closest dealer is condotta's in wenatchee?
p.s. I think I recall that some crack the throttle open slightly when hot - flybars or one of the other regular guys can help you out here...
Loose yellow wire in airbox stevethebrit Enduro Electrical & Wiring 2 09-30-2009 04:40 PM
Blue/Yellow wire disconnect, must you now retrim?? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 11 09-02-2009 05:25 AM
No Yel/Blu wire effect. cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 8 01-12-2009 10:29 AM
04 ec300 CDI wire lead options? socalscott Enduro Engine - 2 stroke 0 05-08-2008 01:21 PM
