Old 03-24-2012, 11:57 PM
stemplin stemplin is offline
I cleaned it up a little better and it does have the vertex name etched in the top.
I guess my question now is should I be ok replacing a vertex D with a Wossner C?
Old 03-25-2012, 12:22 AM
Well here's my thoughts on the matter.
The cylinder is stamped a B. Even with some wear it should be able to accomodate a C. As stated earlier there is only 0.02mm difference between each size. The Vertex is a cast piston. The Wossner is forged. Generally a forged piston will require a little more clearance by nature.
In my personal experiences with the A pistons I found the Wossner to be a better fit than the Vertex. I was comparing a piston with 75hrs on it to a new one though. Make of it what you will.
Unless if you are willing to go and have your cylinder measured up you are only guessing. I'd probably try and source a D quickly, but would also be comfortable ordering a C to drop in. If it felt loose I'd return in.
http://www.wossnerpistons.com/tech/piston-installation
Old 04-01-2012, 05:31 PM
Put the Wossner "C" kit in and it fit like a glove but the problem is no better. I don't know what else to do.
There was a small amount of oily substance inside the ignition cover, could a leaking crank seal be causing these issues?
Old 04-01-2012, 07:43 PM
Ok. Update us on whats been checked/replaced again and what changes it has made.
Sounds like mechanically you might have a solid base to start with.
Old 04-01-2012, 08:46 PM
The list of changes/updates is in my original post + the brand new top end. Nothing has seemed to help at all.
I did pull the crankcase drain plug but nothing at all drained.
I'm just not sure where else to look
Old 04-01-2012, 09:52 PM
Leaking crankcase seal on stator side would be causing a lean condition and a racing idle generally.
Did you investigate the choke assembly as described earlier? Did you drop a fresh plug in with the new top end? BR8ES work well and are much cheaper than the EG. Mechanically you have just about addressed everything so next would be investigating the electrical side further. Something I know next to nothing about.
Old 04-02-2012, 07:00 AM
I was thinking the same thing on lh crank seal but what would account for the oily substance in there?
I didn't put a new plug in but the 1 in it only had 1 ride on it. I'll try that and then start looking into electrical.
Old 04-04-2012, 10:41 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
After reading everything through this thread my money would be on the right side crank seal. I've seen similar issues to what you are describing and you've ruled out about everything else. I think it would be worthwhile to do a crankcase pressure test.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 04-04-2012, 11:34 PM
Originally Posted by stainlesscycle View Post
whoa - just noticed this one. the choke has no effect? is the rubber bumper on the bottom of the choke assembly ok?
Has this been confirmed yet?
Old 04-05-2012, 05:43 AM
No it hasn't. I've visually inspected right hand seal and saw no discoloration of oil in crank when I had the top end off.
I feel really stupid about this but I now suspect the spark plug boot. I hadn't noticed how loose it had gotten but feels like the rubber is really the only thing holding the plug. Would this cause the symptoms I've described?
gas gas won't idle? read this! ricardo cabeza Enduro Intake/Carburetion - 2 stroke 19 10-07-2013 01:33 PM
Bad idle Madhead Enduro Intake/Carburetion - 2 stroke 1 08-11-2011 06:20 AM
Does not idle or rev Binni Enduro Intake/Carburetion - 2 stroke 8 02-14-2011 03:29 PM
can,t get idle up geno Enduro Intake/Carburetion - 2 stroke 1 04-18-2010 08:49 PM
EC 250 05 noo idle. settings?? Laban1234 Enduro Intake/Carburetion - 2 stroke 5 07-21-2009 11:13 AM
