Old 01-23-2008, 12:41 PM
kim kim is offline
Default Ohlins Rear Shock oil change and regassing
Is there a manual anywhere for servicing the rear shock ?
What tools do I need etc
I have searched the net but to no avail so far
K
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Old 01-23-2008, 03:20 PM
Dave Dave is offline
Procedure wise, the following article pretty much covers the tear down and reassembly except for the piston reservoir.
http://dirtbike.off-road.com/dirtbik....jsp?id=266765
I've never found a service manual for the Ohlins shock.
Old 01-23-2008, 05:48 PM
ramcclure200's Avatar
ramcclure200 ramcclure200 is offline
You may have already came across this but this is the only manual I found in my searches of the web.
Its basic stuff but may help.
http://www.ohlins.com/Motorcycle/Pro...0/Default.aspx
Click on:
MX/Enduro/Off-Road shock absorbers
Trial/Off-Road shock absorbers
They are PDF files.
I do know that you need a special needle to insert to fill with gas.
I spoke with a friend who does alot of suspension work and he drills and taps for a schrader valve so it makes adding the gas more universial.
Old 01-23-2008, 09:11 PM
MattR's Avatar
MattR MattR is offline
K
Have you tried this manual?
It was listed in our manuals section off our main page.
http://www.gasgasrider.org/ohlins_shock.zip
Matt
Current: 2009 Yamaha FZ1
Old 01-24-2008, 08:50 AM
blitz11's Avatar
blitz11 blitz11 is offline
That manual (http://www.gasgasrider.org/ohlins_shock.zip) has nothing to do with Ohlins maintenance. Just theory of operation.
I just took apart my shock last week (first time), and changed the fluid. It's really easy, no special tools needed (other than the needle, gas, and regulator to charge the reservoir). It's like any other shock. The only tricky bit is to make sure you set the piston height/depth to where it was upon disassembly. Bleeding the shock is like any other.
I took a few photos when I did mine, so I could write something up if you're interested. I also measured piston depth if somehow that is lost.
I am the second owner of the bike, but the first owner kind of hacked up the shock. I am not sure how that happened as they are quite easy to work on.
blitz
Old 01-24-2008, 01:57 PM
ferguscawley ferguscawley is offline
blitz
Please do. I would be extremely interested in seeing what was involved in doing the ohlins shock overhaul.
Thanks
Fergus
Old 02-01-2008, 05:08 AM
odonovanh odonovanh is offline
Talking
Thanks
Fergus
KTM still rule
Old 02-01-2008, 12:00 PM
webmaster's Avatar
Administrator
FYI - Someone recently sent me a complete ohlins service manual in pdf. I will post it on the website in the next couple of hours...
p.s. Mr Odonovan - if you don't have something constructive to add - please don't post.
Old 02-01-2008, 04:54 PM
webmaster's Avatar
Administrator
An ohlins shock workshop manual showing complete disassembly and reassembly can be found at : (do right click "save link as" - it is almost 5 megs so be patient).
www.gasgasrider.org/ohlins_workshop.pdf
Many thanks to "gaser" for this contribution. I'll add a link to it on the main website.
webmaster
gasgas riders club
Old 02-02-2008, 03:07 PM
That is excellent. Many thanks for posting that.
Fergus
ohlins rear shock problem reeve Enduro Suspension 14 06-01-2014 11:03 PM
07 ec250 will 05 ohlins rear shock fit gasgasandrew Enduro Suspension 1 01-22-2010 04:39 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
Oil change time-which viscosity=fork/shock motorhead Enduro Suspension 5 10-04-2007 06:56 AM
ohlins rear shock broken! tommo Enduro Suspension 4 05-07-2007 07:15 AM
