Old 05-05-2008, 06:14 AM
smithy363 smithy363 is offline
Default battery going flat
hi got a 03 450 supermoto im fully charging battery it last last about 5 miles then going flat. battery in good condition not useing the lights engine cutting out as battery going flat help
Old 05-10-2008, 12:12 AM
anathema anathema is offline
Sounds like you have a stator or regulator problem. First charge your battery with something else (batt charger of some kind) then put it in the bike.
You can quickly verify if the bike will be charging by checking if you have ~14 volts at a nice fast idle. If not, no charging.
If you have determined it is definitely not charging, you have to check your stator. Under the seat/tank somewhere (i havent done this on my gas-gas just my drz so no idea where everything is) you will have your regulator/rectifier. There are 3 yellow wires going into it. You need to check if any of these wires are shorted to ground. Also check what their resistance to eachother is. To ground should be open circuit, to eachother should be fairly low, like an ohm. or less. If any of these are not what they should be, you need a new stator, or at least get it rewound.
Now, on the DRZ I could start the bike with the stator unplugged from the Reg/Rect. Maybe on the gas-gas you cant, I doubt you can because of the FI system. Somehow, you need to measure the voltage coming out of those wires while the bike is running. REMEBER, use AC scale on your meter, not DC like you would for your battery. Measure each yellow wire referenced to eachother. The voltage should be pretty high, i think over 50-60 volts. Wire 1 to wire2, wire2 to wire3, etc, all over 50-60 volts. The voltage will move around thats not a big deal. Nothing precise, just high. If any of those measurements is bad, again, new stator, or some stator work.
If the stator measurement is good, but your battery is showing low voltage with the bike running, then your problem is in the regulator or wiring. Check the wiring first, follow the battery wiring back to the regulator, checking all fueses and look for corrosion etc. If wiring seems ok, you probably have a bad regulator and might want to look at replacing it. If the voltage at the regulator tests good (14ish volts) but the same wire from your battery shows low, then its wiring. If not, its probably the regulator.
Anyways sorry I've never tried to explain the proceedure before and this is all info from me testing my DRZ so hopefully it carries over.
Good luck!!
2k5 GasGas FSE450
Old 05-10-2008, 01:28 AM
Thumbs up
cheers m8 found prodlem corrosion on wire in loom
Old 05-12-2008, 08:42 AM
No prob happy riding!
2k5 GasGas FSE450
Little flat spot jetfish Enduro Intake/Carburetion - 2 stroke 6 02-22-2010 01:17 PM
200 ec flat spot fishlegs General Discussions & Announcements 2 05-27-2009 05:29 AM
Nor. Cal Elkins Flat Ride 5/3/09 Rick General Discussions & Announcements 2 04-30-2009 01:39 PM
ec300 chokes and goes flat Help! clerky clerk Enduro Engine - 2 stroke 13 01-14-2009 01:41 AM
bad flat spot, Help! clerky clerk Enduro Engine - 2 stroke 1 12-07-2008 10:06 AM
