Old 10-08-2009, 09:23 AM
widebear's Avatar
widebear widebear is offline
Banned
Originally Posted by Eric K View Post
Consider that the primary load on the bearings is due to the compression and combustion. The bearings are loaded the same when the engine fires. The rod bearing has much more surface area to distribute the load. The wrist pin bearing is proportionally higher stressed with the same load.
I concur.Extensive testing by Husky ,re; oil ratios, revealed that the most severly effected component by using lean oil/fuel ratios was the top end bearing. Since I only run @100-1. I replace the $12.00 bearing every top end service. I realize that this topic is'nt about oil ratios but as Eric pointed out that little bearing does take alot more abuse than people might at first think.
Old 10-08-2009, 10:18 AM
Trailrider Trailrider is offline
Default Replacing wrist pin bearing
I have been riding for 40 years, replacing the wrist pin bearing, along with the wrist pin, clips, rings and gaskets was always done when the top end was serviced. The possible damage from not doing so is not worth risking the small savings. Racing highly strung 100cc aircooled MX bikes in the early 70's
probably had something to do with it.
Trailrider
Old 10-08-2009, 11:28 AM
GMP's Avatar
GMP GMP is offline
The pin is replaced because it comes with the piston. Sometimes I'll replace the bearing, sometimes not. Yes, its cheap, but depends on if I have one or can get one when I want it. I never seem to notice any wear, but I run 36:1. The point is the rod is just as prone to wear as the bearing and pin, and you don't replace that until a total lower end rebuild. If the pin and top end bearing are obviously worn for whatever reason, it seems like you would be kidding yourself to ignore the rod.
Do you replace a hooked countershaft sprocket and keep the trashed chain?
Old 10-08-2009, 06:08 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
What bike do you have? That's even leaner than I run my trials bike.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 10-08-2009, 08:02 PM
noobi's Avatar
noobi noobi is offline
i think you mean that 100:1 is richer. rich and lean is refering to the volume of fuel not oil. so 32:1 or 40:1 i leaner than 100:1
at least i think thats what its refering too...
i get what GMP is trying to say, in that why replace the wrist pin bearing if you dont do the rest of the bearings, in the same way that you dont replace one wheel bearing if its worn out.
but i also get the hassle that you have to go to in order to get to the bottom end bearings.
i think most people just see that its there and its easy to change so they just do. i did
Old 10-08-2009, 09:07 PM
GMP's Avatar
GMP GMP is offline
What I'm saying is the wrist pin, bearing, and rod surfaces should all wear together. Its not a big deal either way. Who has had a failure? No one I know, and its cheap even if it makes no difference.
Old 10-08-2009, 09:37 PM
widebear's Avatar
Banned
97,99.01 kx 250's and all four of my gasgas two strokes 01x2, 02 200, 03 mc 250. No problems ever and they are all jetted very, very krisp!
Big End Bearing twistywizard Enduro Engine - 2 stroke 15 01-26-2011 06:33 PM
wrist problems gascanuck Injury & Recovery 16 03-17-2009 07:49 AM
Wrist pin snap rings steve Enduro Engine - 2 stroke 9 04-08-2008 08:19 AM
Wrist-pin retention clips FFRDave Enduro Engine - 2 stroke 10 01-18-2008 09:53 AM
Wrist Pain & Thumb Throttle Question RPB111 Injury & Recovery 8 10-22-2007 05:55 PM
