GasGas Member Polls Find out what everyone thinks about it! |
#91
My .02
After reading these posts [and other forums over the years] I decided to make a change.
I had great results for many years with Motul 800 [50:1] in my Yamaha. Upon switching to KTM & Gas Gas I began to notice spooge drip line running down the length of the silencer. It was actually worse with my Gassers than the KTM. Last year I switched to Redline [50:1] and the results were much better but still developed more spooge than I liked. The Motul 800 developed so much that it actually would drip off the silencer onto the swingarm. The Redline mix was better but still dripped about halfway down the silencer and was thick enough to be difficult to clean off. So, for this last weekends ride I made the switch back to Motul but the 710 [based on some posts here] at the same 50:1 ratio. After 2.5hrs of a mix of single track and fast double track, I had ZERO spooge running down the silencer. I will note that I had less "smoke time" on warm up and when hard on the gas out on the trail with the 710 than I did with either the 800 or Redline. Throttle response seemed better and power/torque delivery "felt" stronger. The "non existent" spooge tells me that it is indeed a "cleaner" burning mix. I will keep an eye on things to make sure that it is the case and not a situation that is actually too lean. I think I will stay with this one for a while since one ride may not be a sufficient test. FWIW that is my 2 cents.
2003 GG 300EC/DE [Ohlins] 2001 GG 250XCSOLD |
#92
Amsoil Dominator and 710 are very similar especially if you are a lugger.
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
#93
That was what I also found with the 800/710.
Read some more and I believe the 800 needs a higher temp to burn so if you lugging with slightly rich jetting it will not burn off as well as the 710
#94
800 is designed around high rpm and high load engines, generally, offroad riding doesn't evoke situations where the engine is hot enough for 800 to burn off, hence the spooge. |
#95
Vindicator '11 EC 300R |
#96
Motool 710/800 and Dominator are 2 stroke oils, no valves - no worries.
800 would be for WFO around an MX type track or if you were road-racing a 2T or a very, very fast offroad guy. 710/Dominator are oils for those not WFO all the time, they won't fill up your silencer baffles with un-burnt oil.
#97
It won't carbon up the piston as the oil gets burned in the pipe (unless you are VERY hot in the combustion chamber). Oil isn't part of the combustion mixture, it gets burned off in the pipe (counter intuitive, I know). A low temp oil will burn in the combustion chamber if the engine gets too hot, like you don't have coolant, etc, but in general the oil gets pumped into the pipe where it burns off or spooges out the back.
Phil (New bike pending...) |
#98
In theory oil should separate from gas in the crankcase and only gas should come up the transfer ports to the cylinder but that's not always the case. Low flash point oils are more prone to get burned along with gas, the carbon deposits on top of the piston are the consequence of this .
#99
winter
Ha
you know a lot of guys are not riding now !! I swear the how much and what kind of oil discussions come up frequently in dec. jan. I came up with an excuse not to go out today (too cold + wet) and here I am Stoby |
#100
Too funny...
Thread Tools | |
Display Modes | |
What is your favorite GasGas engine size? | MattR | GasGas Member Polls | 51 | 09-11-2014 10:12 AM |
Favorite picture of yourself on your GasGas. | GreatBritishRob | Pictures & Videos | 43 | 10-07-2011 08:07 PM |
favorite clamps for oversized bars | motogroove | Enduro Chassis & Body | 0 | 05-16-2011 07:42 AM |
Put a few of my favorite pics up on the website.... | Steve@Motowest | Pictures & Videos | 0 | 07-14-2009 08:05 AM |
