Old 09-16-2022, 10:55 AM
Topjimmyk Topjimmyk is offline
Default Power Valve Inspection Question
Hey all! I just bought a 2001 300 ec. Which runs and starts great. Rode it all labor day weekend, which was my first weekend with the old girl. So no issue there...
I popped open the left and right hand power valve covers to do an inspection.
The left side had a lot of spoog that drained out all over the floor but the right side was very clean.
Is this a normal thing or do I have some sort of blockage in the drain tube?
Cheers!
Old 09-16-2022, 12:36 PM
Cheers!
I would check the fitting that threads into the LHS power valve cover. Pull this and give it a good cleaning. Replace the hose that connects to the fitting as well. You will likely always have some unburnt oil in the LHS cover, but it should be draining out the drain hose and not accumulating in the cover.
Old 09-16-2022, 01:00 PM
What is confusing me, is that the drain hose and thread is on my RHS power valve cover (kickstart side). That side was clean. The LHS power valve had all the sploog in it. Am I possibly over looking something
here?
Old 09-16-2022, 02:01 PM
Panagiotis Panagiotis is offline
here?
The RHS hose is facing up so it acts like a vent also because the power valve lever is that side there is a hole for it straight to the crankcase , if any spooge makes it there it will go down to the crankcase .
The LHS has a small hole connecting the power valve with the chamber so the spooge from the power valve goes to the chamber and then drains through the hose .
I am not an expert on this i just think this is how it works on my 2009 model.
Old 09-16-2022, 05:08 PM
Just to clarify. The right hand side is the gear box vent hose. The left hand side is the power valve cover drain. They both serve a different purpose.
Someone correct me if I am wrong. It happens.
Old 09-17-2022, 04:16 AM
So can you bring it up on clutch or throttle?
Read the jetting threads.
Old 09-19-2022, 08:50 AM
Thanks guys,
Sounds like she just needs to be cleaned.
question on reassembly of power valve imsimon Enduro Engine - 2 stroke 5 08-02-2016 03:05 AM
power valve question Getoviq95 Enduro Engine - 2 stroke 2 07-11-2016 02:40 PM
power valve question kp_kp Enduro Engine - 2 stroke 10 03-20-2015 10:35 PM
Power valve bearing question Rabbitist Enduro Engine - 2 stroke 6 11-11-2011 01:35 PM
Another Power Valve question Link Enduro Engine - 2 stroke 4 01-04-2008 03:48 AM
