Old 03-30-2018, 02:54 PM
Chris_tian Chris_tian is offline
Default Ec300 Model 2017 power valve
Hello,
can anyone tell me how to adjust the power valve on my 2017 EC300
In the manuel there are no information about the system.
What is the factory setting and wich one is the best?
Old 03-30-2018, 04:20 PM
Anders Anders is offline
You may take a look in the '15 manual. It describes both how to adjustable and the standard setting for each motor displacement.
Old 04-01-2018, 12:03 PM
Thank you!!
EC300 power valve's left cover assembly question Rampart Enduro Engine - 2 stroke 3 03-27-2017 12:12 AM
Ec300 rattle/power valve issue Smithwoodwest Enduro Engine - 2 stroke 6 12-22-2016 07:46 PM
2001 ec300 power valve free play krazy Enduro Engine - 2 stroke 1 09-26-2015 04:26 AM
'14 EC300 Power valve not opening poelinca Enduro Engine - 2 stroke 9 09-17-2015 02:58 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
