#11
I'm in Australia so I can't be 100% sure what they came with in the states. Ours here came with everything required for ADR (road legal; lights, blinkers, horn, chain guards, speedo).
The OEM unit is a Gas Gas branded Trail Tech for those years.. I think it was the Vector but could be wrong. Even if it doesn't have one the wiring harness should be plug and play. |
#12
This is a picture of a typical 45mm Marzocchi top. Its from my 06 EC200, but my son's 11 EC200 looks similar. You can disregard the thing sticking out from the top triple clamp. That was used for mounting a CRF number plate.
Thread Tools | |
Display Modes | |
FAN KIT FOR EC300 question | Rampart | Enduro Electrical & Wiring | 24 | 08-25-2019 03:23 PM |
EC300 generator question | Rampart | Enduro Electrical & Wiring | 6 | 06-02-2017 11:58 AM |
12 EC300 mapping question | knocklife | Enduro Electrical & Wiring | 1 | 09-24-2014 12:45 AM |
06 EC300 Question | ECTim | Enduro Electrical & Wiring | 5 | 08-27-2014 04:29 PM |
EC300 Dim Electrics Question | rogerc | Enduro Electrical & Wiring | 2 | 03-02-2009 11:47 AM |
