Old 04-16-2018, 01:33 PM
ian1987 ian1987 is offline
Default Tame EC300 power
My 2008 EC300 has just had a full engine rebuild and the stator has been rewound.
I had my first ride on it since the rebuild this weekend and noticed the power delivery is far more harsh than before
Has anyone any tips to tame the power to make and more manageable and easier on my arms?
Old 04-16-2018, 02:56 PM
Heavy flywheel, richer jetting on the needle, FMF gnarly exhaust, add a few teeth on the rear sprocket or drop 1 on the front.
2016 RM-Z450
Old 04-16-2018, 03:07 PM
Cheers. I also went from 13/50 to 13/48 after the rebuild so that may be a factor
Have tried to find a flywheel weight online but no luck, does anyone have a link?
Old 04-16-2018, 03:08 PM
Retard the ignition timing a few degrees. You can also drop the cylinder (thonner base gasket) to move the power and lower in the rpm range.
Old 04-18-2018, 11:18 AM
gasser's Avatar
gasser gasser is offline
The cheapest and best thing you can do is change the needle in your carb to a NE-- Suzuki needle. I run a NEDW in my 250 and it made a world of difference. Bike runs real clean and strong right from idle. Power comes on slower but strong and much more predictable. A G2 throttle with a #400 cam works real well but they are a little pricey (over $100). It gives you more control the initial throttle opening.
I also agree with ian1987 the taller gearing can make the bike more harsh to ride in the tight stuff because it forces you to ride in first gear more which is hard on your arms. Speaking of arms-- leaning forward while accelerating will also make it much easier on the arms.
Old 04-18-2018, 12:02 PM
Mikeyx Mikeyx is offline
Flywheel weight: http://www.rma-offroadshop.de/gasgas...t-pro/a-25028/
I am trying to sell mine as my bike is "Racing" w/ a smaller flywheel to which that weight does not fit.
Extension between the engine block and PV cover also cuts the power peak as well as gives additional torque at low revs.
Old 04-19-2018, 08:38 AM
you can also add a reedblock spacer
Old 04-19-2018, 02:35 PM
(F5) (F5) is online now
Some revalved SSS forks from an 06+ yz helped my sore arms
07 EC300 power band question. Hugh Jarse Enduro Engine - 2 stroke 7 09-30-2017 05:20 PM
2015 EC300 power gains Barbs Enduro Engine - 2 stroke 8 02-19-2016 05:24 AM
EC300 still down on power 19brendan81 Enduro Engine - 2 stroke 64 09-15-2012 12:23 PM
Tame it down a little. BELLY FROM OZ Enduro Other... 19 08-31-2011 10:17 PM
07 ec300 - I need more power! Hollywood Enduro Engine - 2 stroke 27 05-20-2008 02:27 PM
