#51
WildAzzRacing YouTube channel Trail Riders of Southern AZ club AZ State Parks OHV Ambassador '11 EC250R '98 KDX220 |
#53
Haven't we been here before?
At closed you should be on pilot. Unless the base diameter of the needle is too small (when throttle is closed fastest part of needle is still leaving a big ring around it) , then big fat wet droplets of fuel will be escaping past the needle and the nice spray from the pilot is irrelevant. So yes, the needle can affect closed to open unlike the otherwise spot on description of what alters what. Throw away that N1EF and get another needle.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
#54
To further clarify F5’s post. The needle sets in the main jet. So the needle jet is affected by the main jet. If you are on a stock needle still, start with a 175 main and 40p. That should clean it up but it’s still not going to run very well simply because the stock N1EF is a flaming pile of poo and needs to be pitched in the trash bin. Sent from my iPhone using Tapatalk |
#55
Cmon say what you really think
#56
I ordered a couple different needles the other night. They were recommended in some post on here. They are n3cf and a N3EG. Hopefully they are better than this peice of junk one.
#57
If they aren't I'll buy you a puppy. But postage is pretty steep from here so I might have to package it separately.
#58
Got a bunch of different sized mains and pilots. Needles haven't came yet. Here it is running with a 178 main, 40 pilot, stock needle at the leanest with #7 slide. Think i might put the clip down at least 1. It runs great, no lean symptoms or rich symptoms. Smokes while warming up, choke on or off and clears up. I think my air fuel screw is around 1 1/2- 2 turns from seated. Makes me worried to see little smoke. I am running smokeless/asheless amsoil semi synthetic. Low flash point. Something like 175 degrees. I also have mogul 800 to try. Installed new boyesen power Reed's.
I started with a 180 main, 45 pilot, 3rd clip position and the air/ fuel screw was useless. Idle all the way in. It was a dog down low. But as you can see in this video, it's not a dog anymore. Opinions on the profession 2 stroke whispers? Should fatten it up just a little? 42 pilot, put it back on 3rd clip position? Whatever combination i ended up with really opened the bike up. Now i just need a new coolant overflow bottle because i stupidly put a hole in mine with a torch. Not happy about it. https://youtu.be/Z9NdNtlmMOY |
#59
As long as you are running 40:1 with a reputable oil it will be fine. Don't listen to the crazy ratio lunies. You'd run more oil if the bike was higher revving but the 300 isn't a roadrace engine. I used to run motul in my race bikes but it is expensive. (Oh no, not an oil thread. . .run@!!).
You could take the overflow to a bumper repair place and see if it is weldable plastic. Doesn't matter how ugly it looks hidden away so you'd tell them that.
#60
I know this is an older thread, but Im an older guy. How do you know what needle you have? where is the # stamping on it? I have no writing on mine. Same thing on the slide.
Blue/Yellow Wire on ECU/running lean???? | Why Z? | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 10-02-2015 04:22 PM |
Am I rich or lean? | pscook | Enduro Intake/Carburetion - 2 stroke | 6 | 08-01-2012 10:17 PM |
Is this a bit lean or ok | Simmo737 | Enduro Intake/Carburetion - 2 stroke | 7 | 09-11-2011 05:02 AM |
Bike running poorly need some help!!!! | Silver | General Discussions & Announcements | 19 | 08-09-2010 08:05 AM |
Bike running hot - check impeller? | stay_upright | Enduro Engine - 2 stroke | 8 | 07-10-2008 07:49 AM |
