#21
The stock needle has very few fans...anywhere...ever.i just meant if the 18 had the same N1E? as stock as pre18 then the NED/NEC should work well in a straight swap.
2013 ec200r |
#22
The Gas Gas GP and EC head are VERY different in design.. The engine will respond very differently due ot this design difference.
Both heads, IMO, have their associated flaws... The EC head is surely the poorer design between the two.. There exists a lo tof room for improvement with the Gas Gas head design |
#23
I bet you dollars to doughnuts that the head design won’t affect jetting hardly at all. I went from a stock head to an S3 with black insert on my 15 300 and didn’t have to change jetting one bit. Sent from my iPhone using Tapatalk |
#24
I'm curious to know what jetting you ended up with as I just got a GP300 myself.
GG GP300 18 KTM 350EXC 17 GG EC 450, GG EC 250 08, KTM 525 EXC 06, KTM 400 EXC 01, XR400 97, VTR1000 98, VFR750 95, Husaberg FE400 96, RMX250 91, Maico 490 84, IT250J 81, RM250C2 79, Bultaco Alpina 250 77 - All sold |
#25
I no longer have the gp..
#26
#27
GasGas and I decided to part ways. I think the new bikes are really good. Last edited by markwoodlief; 04-11-2018 at 04:46 PM. |
#28
Is it just squish clearance reduction increasing compression ratios? Or has the GP head actually been corrected in volume to give a tighter clearance? Squish band angle to piston dome the same? I have also found that changing head design doesn't really throw the jetting out of the ballpark. You might need to change a jet size here or there, maybe half a clip on the needle, but in many cases the improved efficiency of a well cut head offsets any additional fuelling requirements due to increased compression. |
#29
I don't doubt it. Read my post. Then read it again.
Thread Tools | |
Display Modes | |
SM 250 Tuning | Duffs | Enduro Engine - 2 stroke | 1 | 07-19-2013 11:30 AM |
Tuning rear end. | roostafish | Enduro Suspension | 10 | 10-24-2012 11:07 AM |
Website tuning.... | webmaster | General Discussions & Announcements | 17 | 10-09-2010 12:13 PM |
450fse tuning | jjbaker1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 9 | 03-09-2009 04:40 AM |
Tuning wild hp 450 | gvanminnen | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 05-05-2007 03:56 PM |
