Ec125 crank
Hi all I have a 2006 (I think) EC125 the motor is in a box with no cnrank can anyone tell me please if any other crank will if ( I?ve been told honda cr) will fit or were I might find one regards Craig.
E.g. from Enduropuro: https://www.enduropuro.it/shop/en/cr...125-01-08.html I guess your favorite dealer should be able to get you one.
The engine top end is very similar to a YZ125. The crank uses a YZ connecting rod and crank stuffers but I heard the yz crank will not work in the GG. I have not heard anything about the CR crank crossover.
Thanks I?m checking out a YZ crank see how it goes. Cheers.
Hey,
Did you find out if it works? Thank yoU! |
When it fits, let me know
Gesendet von iPhone mit Tapatalk
4 strokes are only good for power generators |
Looking to buy crank for ec125 2002 model | Gasgasec125 | "Wanted to Buy" & "Want To Trade" | 6 | 09-06-2017 06:47 AM |
EC125 2013 Gas Cap | omersho | Parts | 3 | 09-22-2015 07:22 AM |
Crank Remover and Crank Installer tools for EC250 | Fabry | Enduro Engine - 2 stroke | 5 | 06-25-2013 07:24 PM |
Ec125 | noobi | Enduro Intake/Carburetion - 2 stroke | 8 | 09-18-2009 04:12 AM |
'09 Ec125 | Nhuskys | General Discussions & Announcements | 8 | 11-10-2008 07:07 AM |
