Float Pin Problems!
When I tilt the carb to change jets and remove the bowl (while on the bike,) the float pin inevitably drops out the "back" and falls into some crack or crevice to hide.
What is the solution for this?? Is there some way to lock it in place? Thanks, Jeff |
You can replace pilot and main by removing the 17mm bung, no need to remove the bowl.
Haha I was confused first time I read it thinking how does the float pin fall. Bowl off of course. Like Rod said, pull the bung plug and you can access both through that. Small flat blade for pilot, or 6mm socket for the main.
Bet your glad you posted now, all sorts of knowledgeable helpful people on here, V-tec |
Not with the old ASI carb, bowl off to change pilot.
Thats funny! pisses me off everytime it happens to me! I would never admit it but since no one knows me here I was doing the samething.
That is awesome, guys! I am embarrassed to admit that I didn't see it, but that is awesome!
Jeff |
We're very observant us Aussies.
Hey, out riding today and removed the 17mm bung, and what to my wondering eyes should appear but...the main jet, and main jet only. I can't seem to access the pilot? This is an '05 DE 300. Did PWK make different size "bungs?"
Jeff |
Just incase if you missed it Glenn knows his AS1. I havent had to play with one yet.
Float issues | JoshP | Enduro Intake/Carburetion - 2 stroke | 16 | 05-24-2009 05:50 PM |
Float Fix | gasser | Enduro Intake/Carburetion - 2 stroke | 1 | 03-29-2009 10:32 AM |
ec 250 float heights????? | twibs | Enduro Intake/Carburetion - 2 stroke | 22 | 02-27-2008 01:49 AM |
Float height ??? | bens25au | Enduro Intake/Carburetion - 2 stroke | 3 | 08-01-2007 04:28 AM |
Float Bowl HELP! | gasIdaho | Enduro Engine - 2 stroke | 3 | 07-18-2007 09:30 PM |
