Old 02-23-2018, 02:56 PM
Trailrider Trailrider is offline
Default 2010 ec300 won't idle
I have a new to me 2010 ec300 with RB head and carb mods. It has the RB needle, 40 pilot jet, clip on 3rd position. It will not idle, idle screw all the way in. Should I put in a larger pilot jet or what. Will a JD jet kit help? Thanks in advance,
Jim
Old 02-23-2018, 03:27 PM
New to you = many unknown variables.
As I start I'd suggest pulling the carb out. Double check the float heights, blow out the passage ways, check the pilot for obstructions (replace with new if any doubt). Set the float, set the AS to 1.5 turns out from seated, set the idle screw so that the slide only has around 1mm visible through the carb body.
The aim is to get the bike to start and idle at these positions (give or take a bit).
While you're at it it wouldn't hurt to pull the reed block and inspect for any chipped/damaged reeds.
Old 02-24-2018, 02:06 AM
(F5) (F5) is online now
Who cares if it won't idle? Does it pull awesome off a closed throttle?
Can you trials it around in the forest? That's what's important.
Old 02-24-2018, 04:58 AM
Default 2010 ec 300 won't idle
F(5) the bike rips with the RB mods but will not idle. Does it need a bigger pilot jet?
I may call RB or get a jd jet kit. Riding without idle is not really an option.
Old 02-24-2018, 08:18 AM
risk74 risk74 is offline
My 300 has the RB mods and is reluctant to idle. Runs very well otherwise. I am running a 45 pilot, anything less and the bike can be hard to start.
I believe Ron suggests 1 turn out on the air screw as a good starting point. He also recommends making small adjustments (1/16 of a turn at a time!) to the air screw because the mods make it so much more effective than stock.
Old 02-24-2018, 12:23 PM
RB hooked me up with the proper jetting, mine was incorrect. Runs great now.
Thanks for the advice.
Trailrider
Old 06-13-2019, 10:36 PM
adriano.ro adriano.ro is offline
Trailrider
And the jetting specs are......?
EC300 dies slowly at idle when warm Mikeyx Enduro Intake/Carburetion - 2 stroke 14 08-19-2017 01:05 AM
1999 ec300 wont idle. uk ohffs Enduro Intake/Carburetion - 2 stroke 3 08-25-2013 03:07 PM
Help 04 ec300 wont idle nmhinton Enduro Intake/Carburetion - 2 stroke 18 08-31-2011 10:51 AM
EC300 Idle Revisited. Ud_luz Enduro Intake/Carburetion - 2 stroke 35 01-07-2011 07:39 PM
2001 EC300 won't idle - can't get jetting right bexi Enduro Intake/Carburetion - 2 stroke 16 03-04-2010 10:30 PM
