All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki... |
Yamaha GYTR Wheel Kits
Does anyone know if these complete wheels will work on a gasser?
http://www.yamahamotorsports.com/spo.../0/detail.aspx
Front brake disk is smaller diameter on the Yamaha (250mm on the Yamaha aganist 260mm on the gasser). Can be made to work by buying / making an oversize disk or moving the gasser's caliper. The front axle diameter on the Yamaha is smaller (could be fixed with other bearings, I presume). The rear one I don't know, but unless you usually win the lottery, I wouldn't bet on it.
ec300 piston kits? | motopsycho87 | Enduro Engine - 2 stroke | 2 | 08-01-2013 05:20 AM |
Brake caliper kits | cladoo | Enduro Other... | 2 | 04-19-2012 06:47 AM |
Graphic kits | NSE.ONE | Enduro Chassis & Body | 4 | 11-19-2009 06:03 AM |
GasGas Bolt Kits? | JoeH | Enduro Chassis & Body | 5 | 07-01-2009 03:24 PM |
graphic kits | 2stroker | Other GasGas Bikes/Quads | 0 | 11-02-2008 08:20 PM |
