Old 08-30-2012, 09:02 PM
Koko Koko is offline
Default Shifter woes...why am I the only with these fitment issues?
So I ordered one of the cheaper levers from Niche Cycle and when I mouted it up, it hit my ignition cover. So I returned it, then ordered a TMV shifter.
Off comes the stocker one goes the TMV...same issue. It's because both shifters are longer than stock. They have the same bend, but their length screws things up. The added length would be welcomed with my size 13 shoes.
Sorry for the bad pics. For some reason my pegs look bent. They're not. It's just the odd picture angle with my junky cell phone camera.
Stock
TMV
2005 GasGas EC250
2012 Kawasaki Brute Force 750 w/ EPS
Old 08-30-2012, 09:07 PM
jeffs2200 jeffs2200 is offline
Your ignition cover seems to stick out awfully far. I think that is the problem. Do you have some sort of large flywheel or weight? The niche shifter fit my 2011 perfectly.
Old 08-30-2012, 09:13 PM
No idea. This bike is (new to me). The cover says gasgas on it?
2005 GasGas EC250
Old 08-30-2012, 09:19 PM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
I use mine without the circlip fitted and tightend on the slinned shaft to give clearance at the toe end.Just check that bolt now and then for tightness.
Old 08-30-2012, 09:26 PM
PEB PEB is offline
Heat it up and bend it to fit.
Old 08-30-2012, 09:28 PM
I was worried about decreasing it's strength if I do that. But that would easy enough with some heat and my vise.
2005 GasGas EC250
Old 08-30-2012, 11:38 PM
(F5)'s Avatar
(F5) (F5) is offline
I cut mine & got it welded, cover looks exactly like mine.
Using it without the circlip is inviting lose. Trust me its no fun walking back 1 mile trying to remember when you last changed gear in single track & still not finding it & having to finish the loop stuck in 3rd (luckily not say 5th).
I tie wired a loose loop of wire to the lever & back to the frame so if it does jump off it doesn't go far. Bolt doesn't retain like a jap bike.
Old 08-31-2012, 03:21 AM
stainlesscycle's Avatar
there are at least 3 different stock shifter levers for the gg. they must have patterned it after the longest one. if you use the longest one (like these aftermarket ones..), when you have a left side get off, the shifter will bend and not clear the stator anymore. and you won't be able to shift up. you will need to modify the aftermarket ones by either shortening, or grinding the back side, or mounting downward - either way imho they're all junk, and bend quite easily.. i will mount the suzuki one today and take some pics. i have a few variations (different gg #'s) i can mount/take pics of to show which ones may work for you.
also, you gotta use the circlip! i have to tighten the shifter before every race - the splines of the shifter are probably too fine and just a little wear/one time of using it loose, and it'll continually loosen forever. not to mention the aftermarket ones sometimes have the bolt on the top, and sometimes on the bottom, so accessing the pinch bolt can be tough. and there's no clearance to use a longer bolt and a nut (maybe a jam nut will fit and allow the shifter to operate without hitting the frame - gotta check)
07 ec300
www.stainlesscycle.com
Old 08-31-2012, 06:09 AM
Thanks Stainless. Truly appreciate your help. I'm looking forward to the pics of the shifters along with the RMZ one. If there's one that fits better, I have no problem returning this one to get one that fits without major modification.
I appreciate the feedback everyone!
2005 GasGas EC250
Old 08-31-2012, 08:25 AM
2004 rmz 250 shifter does NOT fit. splines are wrong. pics of 3 different shifters with info coming in next post.
07 ec300
exhaust fitment bonkeye Enduro Engine - 2 stroke 10 05-29-2012 12:22 PM
Pipe Fitment (DEP) C-UK Enduro Engine - 2 stroke 6 07-17-2011 10:56 AM
plastic fitment randy General Discussions & Announcements 11 02-03-2010 03:03 PM
water pump woes skid jackson Enduro Engine - 2 stroke 0 05-16-2009 02:19 PM
air filter fitment wence Enduro Engine - 2 stroke 6 12-23-2008 09:49 PM
