Old 08-31-2018, 05:22 AM
Default Headlight mount/rubber straps
Has anyone here removed the rubber straps from a headlight shroud without a) busting the headlight, or b) busting the shroud.
I have a spare 2013 shroud that I'm considering mounting to my 2018, keeping the actual headlight, indicators, etc clean and new. I don't use the light anyway. To do so I need to remove the rubber straps, without damage to either.
The other option is I just order a second pair. Ref.BE25636015
Old 08-31-2018, 05:40 AM
john r b's Avatar
john r b john r b is offline
A little silicone will help removing the straps.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 08-31-2018, 06:04 AM
That's what I was thinking. Have some nice slick silicone grease here...
Old 08-31-2018, 12:12 PM
Anders Anders is offline
Yes, I have done this several times. No problem.
Old 08-31-2018, 05:29 PM
Sweet as. Bit of silicone and then a good push with the thumb should do it!
Old 08-31-2018, 06:25 PM
Turn the lights down, some smooth jazz,
Old 08-31-2018, 09:26 PM
I was waiting for you to chime in F5!
Headlight straps BassMunn Enduro Chassis & Body 8 11-25-2016 04:18 PM
headlight plastic/rubber strap fix barossi73 Enduro Chassis & Body 2 06-01-2016 02:23 PM
Headlight straps... GGRider01 Enduro Chassis & Body 2 09-03-2015 09:58 PM
Rubber straps Rabbitist Enduro Chassis & Body 4 06-01-2011 05:10 AM
