Old 06-18-2017, 04:35 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Default Power valve end play, side to side movement, rattle...
Hi all
I recently bought a well used 2004 EC300. The engine seems to be in good condition. It was running a bit rough but after adjusting the carb it's running sweet now.
My last remaining issue is a terrible rattle, it's very noticeable on overrun, for example rolling down a steep bank with the throttle shut.
I removed the left and right power valve covers and also the exhaust. The power valve seems to be well adjusted, it sits against the closed stop and has no slack in the mechanism.
I stuck my fingers up the exhaust port, I could feel a lot of side to side play/movement of the power valve. When I move it left/right I also hear the horrible rattle that I hear on overrun.
Questions:
1. Is there anyway to remove the sideways movement of the power valve (possibly with shims?) and thus reduce or eliminate the horrible rattle noise that I have?
2. Is it possible to remove the power valve unit without removing the cylinder head/barrel from the engine?
Thanks and best regards, Dave.
Old 06-18-2017, 06:55 PM
Originally Posted by Davehuge View Post
Hi all
Questions:
Yes, you can remove the power valve without removing the cylinder. You will need to remove both PV side covers and get the piston at BDC. It should come out the exhaust port. I would remove the head so you can push the flap out.
Old 06-19-2017, 03:34 AM
poelinca's Avatar
poelinca poelinca is offline
Not sure about 2004, but on my 2014 i removed most of the side to side movement by pressing the left hand side bearings in a bit more (just a tad, maybe less than 1mm, if i press them more the PV get's stuck probably on the left exhaust valve).
p.s. Did you check the rocker arm on the right side or the bell crank hitting the case ? It's pretty common for them to bang on the cylinder or case, to check remove the right side PV cover, put the pipe back in, start the bike and rev it a tad, you will see the rocker arm moving and rattling, make sure it's not banging on the cylinder (if it's banging on the case, you should see marks on the case, you have to drain the coolant, the case oil can stay in just lean the bike on the left side when removing the case cover). Here is a video on youtube that helped me out a lot in removing most of my rattles at high rpms https://www.youtube.com/watch?v=dI0fUUHaDjQ
'14 EC300
Old 06-19-2017, 08:26 AM
you sure it is not the exhaust o-rings that are worn?
Old 06-19-2017, 05:48 PM
My experience has been that they are just noisy old 2 strokes. The pipes can rattle against the spigot, against the mounts if not aligned correctly. The rads/braces can vibe up against thing. Plastics can clatter. Bash plates will rattle. Everything is always way more evident on decel because:
a) the exhaust isn't making any noise to cover it up, and
b) as the revs fall it always goes through the range where the crank is least balanced. This increases the vibes, felt, heard, etc. Under throttle you tend to have a load on the piston and also move through this area faster.. Find it and hold a steady throttle and it'll buzz away through the bars and pegs more than most would enjoy.
Old 06-20-2017, 04:19 AM
Davehuge's Avatar
Thanks for the advice and suggestions.
I'm a bit busy at the moment but as soon as I've investigated it more I'll post feedback.
All the best, Dave.
Old 11-21-2021, 04:45 PM
JAD JAD is offline
Cool... Many thanks. I shall check mine.
Sent from my LLD-L31 using Tapatalk
Retired
EC 250 (2007)
UK
Side cover power valve bearings? Terrence R Enduro Engine - 2 stroke 19 04-29-2016 07:26 AM
Power valve rattle on 2012 tonyraft Enduro Engine - 2 stroke 6 09-27-2013 11:52 AM
POwer Valve Rattle PEB Enduro Engine - 2 stroke 3 03-22-2012 10:33 PM
Power valve rattle dickieshep Enduro Engine - 2 stroke 1 07-03-2011 01:33 PM
power valve rattle not chain slap gasgasandrew Enduro Engine - 2 stroke 47 06-11-2009 05:24 PM
