Old 02-25-2014, 12:46 PM
Niall-griffiths's Avatar
Niall-griffiths Niall-griffiths is offline
Default Brake caliper bolt snapped
Came home and as i pulled onto the drive my rear brake caliper was loose and locked the back wheel up/ lucky i got home and wasent riding still. the fixing (not sure what its called) inbetween the swingarm and wheel what the top caliper bolt screws into must of been cracked and has broken off and nowhere to be seen. where can i get one from or would one of a 250 like this fit?
http://www.ebay.co.uk/itm/Gas-Gas-EC...item2ecefec51c
Bike is a 2002 ec 300
Old 02-25-2014, 02:06 PM
pscook's Avatar
pscook pscook is offline
200/250/300 are the same chassis from what I have read, so any frame/chassis/brake bits should swap right over.
Phil
(New bike pending...)
Old 02-25-2014, 02:46 PM
Hi mate thanks for that. D u know what the part I'm talking about is called so I can give seller details easily ??
Old 02-25-2014, 05:37 PM
cbutler's Avatar
cbutler cbutler is offline
A pic would be helpful
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 02-25-2014, 06:21 PM
pscook's Avatar
My guess from your description is that it's the caliper bracket. It has a slot in it to hang on the swingarm tab as well as a hole for the rear axle. It acts as the wheel spacer as well as caliper bracket.
If it looks like this, then you have a part number as well.
http://www.gasgasrider.org/forum/sho...26&postcount=7
Entire thread here:
http://www.gasgasrider.org/forum/sho...racket+caliper
Phil
Old 02-26-2014, 12:49 PM
Thanks thats what im after dont know why it snapped it seemed fine before had alot of stones hitting the bike from being pebble dashed tho.
Brake caliper help! yourmatedave Enduro Chassis & Body 5 05-18-2013 04:40 AM
Brake caliper kits cladoo Enduro Other... 2 04-19-2012 06:47 AM
Rear Brake Caliper blitz11 Enduro Chassis & Body 11 10-28-2008 03:38 PM
TrailTech speedo -- brake caliper whole outside the arc AZRickD Enduro Electrical & Wiring 17 07-30-2008 12:13 AM
