Cometic Gaskets
I just noticed that Cometic has engine gaskets for 2 stroke GG engines. They split them into a top end kit and bottom end kit. http://www.shopengineparts.com/parts...Up)&type=model
Priced together they are about 20% less expensive than the GG overall engine kit but most of the time I don't need the whole kit. Additionally you can buy them individually. http://www.shopengineparts.com/parts...Up)&type=model I don't know for sure yet, but I am willing to bet they don't charge $15 to ship an O ring. |
I've had good luck with cometic on cars, but had a bad cometic head gasket on my old RMZ450 right out of the package. An oem gasket fixed the problem. Pretty hard to screw up an o-ring though. Anyone else have any experience with them?
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
I have used them several times. The only problem I had was with the water pump cover gasket being the wrong size. I think this changed from 11-12 and they had not caught that. They now have the correct water pump gasket for the 12-13 in the kit. Just installed top and bottom end gaskets on my 13 with no problems.
Just used them from Powersports. Seem well made. A couple of rides in & look fine.
The came with my YZ250 top end kit and the gasket was wrong, had to go out and buy an OEM. Cheap = expensive.
Airbox and gaskets | ECTim | Enduro Engine - 2 stroke | 8 | 11-29-2013 06:12 PM |
Which base gaskets? | motopsycho87 | Enduro Engine - 2 stroke | 1 | 10-01-2013 06:14 AM |
top end gaskets, size 200/250/300 | hannesd | Enduro Engine - 2 stroke | 2 | 01-22-2013 12:57 PM |
Gaskets? | Harry | Enduro Engine - 2 stroke | 6 | 11-17-2011 11:50 AM |
125 gaskets | noobi | Enduro Engine - 2 stroke | 0 | 04-23-2009 05:08 PM |
