GasGas EC 125 2010 crank assy
Hi, I have a GasGas EC 125 2010 with a damaged crank assembly in need of changing, but I can?t find anyone who sells one. I have however read that some years of Yamaha YZ125 has the same engine and I’ve also found a crank assembly for 01-08 model years. Anyone know if the 01-08 will fit and if not, why? Also if anyone knows if any Yama crank assy fits and if so, which?
Thanks on beforehand, Julian |
They use the same rod and crank stuffers as the older yz125 but other parts are different. If I recall correctly the flywheel taper is different and trans primary gear shaft size and spacing is different.
Just get your crank rebuilt. |
Tags |
#ec125 #crank |
Stuck R PV Assy (R) | Svensk | Enduro Engine - 2 stroke | 10 | 06-27-2019 04:25 PM |
Crank Remover and Crank Installer tools for EC250 | Fabry | Enduro Engine - 2 stroke | 5 | 06-25-2013 07:24 PM |
2010 GasGas Demo Day at Battle Creek MI May 22, 2010 | twowheels | General Discussions & Announcements | 12 | 06-14-2010 06:29 AM |
Rear Wheel Assy. Ktm 525,520,505,450,300,250,200,125 | 42GEORGE | All Other Bikes... | 0 | 03-09-2007 03:32 PM |
